carpet for a '65F350
Old May 13, 2003 | 10:04 PM
Buford65's Avatar
Buford65
Question carpet for a '65F350
I was told the body on a'65 F350 is the same as a '66 F100. Do I need to order carpet for a '66, they don't ask what model F series, just the year ? Just got my '65 this week and ready to get started !
Old May 14, 2003 | 06:12 AM
William's Avatar
William
Carpets are the same from 65 through 72. There is a difference between floor shift and column shift because of different height of the center hump. Get a quality carpet and check Motorhaven on this site he may have it.
Old May 14, 2003 | 01:04 PM
Charles-65F350's Avatar
Charles-65F350
Are you sure about that? The '65-'66 F-350 cab floor is the same as the '61-'64 (not the '65-'66) F-100 and 250, so wouldn't the shape of the carpet be expected to change too?
There also needs to be a "hump" in the middle for the transmission cover. From '67-72 are all the same, I think.
Old May 14, 2003 | 04:55 PM
Rosati's Avatar
Rosati
Order the 64 F100 carpet with floor shift if your trans hump is bolted on.
Order the 64 F100 carpet if you have a column shift.
The 65 F350 body style is the same but the floor pans are a carry over from 64 F100 through F600.
Old May 15, 2003 | 10:35 PM
Buford65's Avatar
Buford65
I was told the cut out in the floor for the step in was the same as a '66. Were the 350,250 and 100 series all the same in '65? It is a 4 speed manual tranny on the floor with a dual lever 4x4 control,thanks for all your help
Old May 16, 2003 | 11:19 AM
Rosati's Avatar
Rosati
The entire floor pan in the 65-66 F350 trucks are identical to the floors in the 61-64 F100-F350 trucks. The only exception being tha trans hump. If the trans is a 4speed, floor shift, the hump is higher and wider (also bolted in) If the trans was an auto or a column shift, the hump is lower and narrower (is not bolted in ).
The steps, seat mounting points and everything else is the same.
Old May 20, 2003 | 06:39 PM
phjbbu's Avatar
phjbbu
My two cents is that the '66 F600 floor is also the same as the '64. I have a bias in raising the 600 whenever I can. I just got one and even though I also have a '64 250, I realize I have one heck of a lot to learn on the 600. Any learning partners I can find on this site will help a great deal, I'm sure.
Fordman697
Sep 23, 2014 02:58 AM
The Masked Rider
Jul 14, 2013 03:31 PM
ford66
Sep 26, 2009 06:54 AM
Studenut65
Jul 5, 2006 05:58 PM
Charles-65F350
Jan 3, 2001 08:02 PM
