1978 - 1996 Big Bronco
What did you do to the Bronco Today?
  #3391
Old 04-18-2018, 01:21 PM
MAL1978's Avatar
MAL1978
MAL1978 is offline
I wonder if the error came because I'm using Fedora (Linux)
Yes sorry, new to posting I have a 1978 Ford Bronco 4x4 351 Cleveland
I ended up putting a bit of adhesive on it so it would stick!!
  #3392
Old 04-26-2018, 10:31 PM
mountain dewd's Avatar
mountain dewd
mountain dewd is offline
Got my third member back in and drive it to a car show.
  #3393
Old 05-09-2018, 08:49 PM
graflexmaster's Avatar
graflexmaster
graflexmaster is offline
puked the rear D/L U-joint, and in the process it took the rear D/L yoke with it..... So tomorrow will be at the wrecking yard to get a new/used Rear D/L... and another $50 spent.... lol that's ok, for a $100 rig?? it has been a jewel..........>>GRIN<<
  #3394
Old 05-10-2018, 03:27 PM
mountain dewd
Vacuumed it out, put in a back seat, painted the air cleaner housing and pulled the top off.
  #3395
Old 05-10-2018, 03:49 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
trimmed 1/4 inch off all around the dodge clutch to fit the ford PP ( "it;s the splines, matie." ).
Painted the Transfer w/ a top coat rattle can of POR15. Now that was a new 1 on me...
Know if I shoulda used an undercoat 1st?
  #3396
Old 05-16-2018, 11:54 PM
SDDL-UP's Avatar
SDDL-UP
SDDL-UP is offline
Paint! I got my front axle taken apart and sandblasted, primed, and finally shot the small parts with some industrial Imron this evening. Man that felt good! Assembly is only a week away!
  #3397
Old 05-17-2018, 01:42 AM
fordtrck302's Avatar
fordtrck302
fordtrck302 is offline
SDDL YOU should post a picture!
  #3398
Old 05-17-2018, 10:01 AM
chrlsful's Avatar
chrlsful
chrlsful is offline
need window?
Originally Posted by MAL1978
... I have a 1978 Ford Bronco 4x4 351 Cleveland
Sorry only have prts for 1st gen ALTHO
the 2 yr 2nd gen is my fav lookin!!!
My over all fav truck (or vehicle @ that rate) is the 4X4 F250 short bx/step side '73/9 (w/this 2nd gen bronk - tied).
Double 18 inch racing stripe'd do it too.
  #3399
Old 08-08-2018, 11:23 PM
phillips91's Avatar
phillips91
phillips91 is offline
Put a new battery and starter solenoid on it. Going to change the oil tomorrow.
  #3400
Old 08-15-2018, 07:09 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Tried to start the Bronco after a year to no avail... I'll have to check the timing very thoroughly.
  #3401
Old 08-15-2018, 09:40 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
timing doesn't change frm that.
More description gets more answers.
  #3402
Old 08-15-2018, 10:15 PM
Encho's Avatar
Encho
Encho is offline
I replaced the distributor, the new one might be off even though I marked the spots, so that's why I suspect that might be the cause. Initially the truck was running but there was a very noticeable missfire, the first suspect was the PIP sensor, so the distributor was replaced. I'll list what else is new or has been recently replaced: The fuel pump is new, the sparkplugs and cables, the IAT, the TPS, the ICM, all of those are new. The fuel injectors were tested and cleaned, the throttle body was cleaned. The ECM was also rebuilt.
  #3403
Old 08-24-2018, 06:11 PM
MadMatt65's Avatar
MadMatt65
MadMatt65 is offline
Been a while since I last posted. Have been fighting a chirping belt. Finally found the power steering pump pulley not lined up (my fault) Got it pulled and lined with a straight edge. Removed the crooked Ford Motorsports air pump delete pulley bracket and installed a billet one from LMR. Lines much better!! Had to run a slightly smaller belt. Installed a new water pump as the temp runs up a bit while idling in traffic or while on the interstate??? Thought maybe the water pump impeller might have been rotted/rusted off some. It wasn't.
Any ideas??? I have a new radiator (NAPA/Spectra), new head gaskets, new thermostat housing and 160 thermostat and new water pump. Doing the same thing!! I'm at a loss!
Anyway.......has been running very good since the head gasket job!
  #3404
Old 08-24-2018, 08:07 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
Originally Posted by MadMatt65
Any ideas???
I'm gunna *** - u - me U gotta a 302 as U did not mention.
Bronks R notoriously hot under the hood, therefore:
make sure U gotta shroud,
fan is '1/2 in it & 1/2 out of it'.
U did a good full system flush.
timing is S P O T on.
U could swap out inner fenders for the 'fender grills' (oneada typical after mrkt bronk vendors sells em).
swap out thermostat winter/summer (lower/higher).
antifrz/anti boil is 50/50%.
no radiator clogs.
H2O pump is 4 an a/c vehicle.
Can't stress Zeroin in da timing enuff...
  #3405
Old 08-27-2018, 06:48 AM
MadMatt65's Avatar
MadMatt65
5.8
160 t-stat
new 50/50 coolant
shroud/fan....check!
I will recheck the timing....but pretty sure it's right on....had to put in a new distributor with the head gasket job.
Doesn't get hot, but can definitely see the temp rise in heavy traffic and while sitting. It is summer and it gets scorching hot here in SW Florida!!
Quick Reply: What did you do to the Bronco Today?
