What did you do to the Bronco Today?
#3181
on
did a fuel pressure test to try and figure out why the 95 bronco is running rough/ misfiring. Sure enough no fuel pressure when key on engine off and a little low while on.
I am pretty sure the check valve is broken but dad thinks the fuel lines are clogged. Time to figure out which one it is.
On the 91 bronco we reconnected the fuel line from the damage that someone did.
Trav
Trav
#3184
on
put new door pins in the drivers door of the 95 bronco and got some for the passenger side. Now the door close correctly.
My 83 bronco I picked up a new used grille in better shape for me to make my custom grille. Also a right side turn signal housing since mine was broken. Now I have everything for the grille assembly stuff just need to get it painted to put everything back on. Got the grille and turn signal housing for $5 for both.
Trav
Trav
#3185
Was out by Omaha / Elkhorn and stopped to take a picture on the historic Lincoln Hiway.
This is after installing the new front springs so that I could get my 33's installed without them rubbing.
And I got the windows tinted a while back. You might be able to see the tint on the upper windshield.
#3187
#3188
Still chasing a stupid off idle miss/hesitation. It's getting better the more I drive it (it seems).
Changed the stock coil with an Accel Super Coil. Going to change either the pickup in the distributor or change the distributor. Anybody know if a 1993 5.8 has a steel or cast iron distributor gear????
I guess I'm going to have to change my evaporator. A/C not blowing very hard through the vents. Checked the mode door and it's working. A/C pressure is going a bit high on the high side.....and with it not blowing very hard .......evaporator.
I gotta look on LMC or BG to see if the new foam is available for the mode doors. Getting a bit blowing through the defrost vents when on A/C max high.
New transmission is still doing good!
All in all......been driving good though!!
#3189
#3193
