What did you do to the Bronco Today?
#2251
#2252
Got the oil and filter changed today. Topped off the front end, transfer case, and rear end. Stripped out the horrible smelly carpet. Got the rear window working. Gear was stripped, switched it out with another one I had.
Gonna take some of the better parts on this one and put on my 78(camo). Gonna use the 79(red) to play in.
#2254
#2255
on
I just went out and crawled under mine as Encho said I had a full time
203 case. I have an NP208F. Anyone know for sure if that is a full time
case or not? I don't remember my front shaft still turning with the locking
hubs out. But he has me wondering so the next time I move it I will check.
#2256
#2257
#2258
#2259
#2260
#2262
Differential Identification | West Coast Differentials
Got some Sterling 10.25 disc brackets from Ruffstuffspecialties.com and they didn't come with spacers. Anyone know where I can get a spacer since I have a 95' axle which is when they changed the outer axle bearing thickness requiring 1/8th spacer.
Also hauled a 8000lb work trailer on my new hangers and was quite surprised to see the truck sat level. (Pic to come)
#2263
#2265
I'm getting a bit frustrated. Been trying to get the wiring hooked up on this engine, ('94 engine, '91 bronco) if I don't get these wires figured out I may end up pulling engine harness and going back to the '91 engine harness!
I reinstalled the hood and aligned it, tapped out a couple dents, scrubbed the heck out of the interior, Looks almost new again! Having troubles getting the correct wheel studs for the 10.25 axle so I will bw taking the hub in and trying studs on it Monday.
