Splayed valves..
Old May 13, 2003 | 09:18 PM
Jimmy Dean's Avatar
Jimmy Dean
Splayed valves..
Does the 351M have splayed valves like the Cleveland?
Old May 13, 2003 | 09:50 PM
Coondawg's Avatar
Coondawg
Splayed valves..
The heads on 351C 2V, 351M, and 400 are the same with very minor differences in the years. None of the differences are valve angles.
Old May 13, 2003 | 10:12 PM
Jimmy Dean's Avatar
Jimmy Dean
Splayed valves..
Thanks
Old May 13, 2003 | 10:28 PM
Torque1st's Avatar
Torque1st
Posting Legend
Splayed valves..
"Canted" valves are normal for the entire Cleveland family as well as the 385 series engines.
Old May 21, 2003 | 08:34 PM
Jimmy Dean's Avatar
Jimmy Dean
Splayed valves..
What all engines are in the 'Cleveland' family??
Old May 21, 2003 | 08:55 PM
GT40man's Avatar
GT40man
Splayed valves..
the Ford 335 series or Cleveland engine family has the 351C, 351M, 400. If you just consider the heads you can add the 302 Boss. some mods are needed for these heads.
Old May 21, 2003 | 09:06 PM
Coondawg's Avatar
Coondawg
Splayed valves..
The "Cleveland" family, properly referred to as the "335 series", consists of the 351 Cleveland, 351M, and 400. The Cleveland name was issued by Ford to differentiate the the engine from the "Windsor". Helpful when there is two completely different engines of the same displacement in production at the same time.
The "Windsor" family has 221, 260, 289, 302, 351 Windsor.
The "385" family has 370, 429, 460.
The FE family has 352, 360, 390, 406, 410, 427, 428.
This is probably a little basic and incomplete but should help.
Old May 21, 2003 | 09:20 PM
Jimmy Dean's Avatar
Jimmy Dean
Splayed valves..
Thanks, and do all the cleveland and FE family engines have splayed valves?
Old May 21, 2003 | 09:45 PM
Brian S's Avatar
Brian S
Splayed valves..
are not used on FEs or Windsor(non Boss) engines.
One other engine in the 335 series is the Australian built 302C.
Old May 21, 2003 | 10:13 PM
Jimmy Dean's Avatar
Jimmy Dean
Splayed valves..
splayed, canted waht is the diff?
Old May 21, 2003 | 11:11 PM
bubbaf250's Avatar
bubbaf250
Splayed valves..
From the Merriam-Webster Web site at http://www.m-w.com/
Main Entry: splay
Function: verb
Etymology: Middle English, short for displayen -- more at DISPLAY
Date: 15th century
transitive senses
1 : to cause to spread outward
2 : to make oblique : BEVEL
intransitive senses
1 : to extend apart or outward especially in an awkward manner
2 : SLOPE, SLANT
Main Entry: cant
Function: verb
Date: circa 1543
transitive senses
1 : to give a cant or oblique edge to : BEVEL
2 : to set at an angle : TILT
3 chiefly British : to throw with a lurch
intransitive senses
1 : to pitch to one side : LEAN
2 : SLOPE
So, when looking at the heads from the top, where angles of the valve stems diverge, you could say the valves are "splayed." Obviously, when looking from the bottom, that would not be true.
In their technical literature, Ford referred to this design feature as "canted valves."
Old May 22, 2003 | 10:29 AM
Bill_Beyer's Avatar
Bill_Beyer
Splayed valves..
Welcome Back Bubba!
TMI
Jul 6, 2014 09:21 AM
wurkinstiff
Jun 28, 2012 07:39 PM
HAARubicon
Jun 30, 2009 05:04 PM
bronco521
15
Dec 19, 2006 02:26 PM
84Maztang
Jun 13, 2003 04:58 PM
