Fix for noisy 'smog' pump
Old Aug 22, 2012 | 02:31 PM
pfogle's Avatar
pfogle
Take it off the truck, pull it apart and grease the bearings. It's a rotary bellows. There is no heat going through it. It doesn't compress any air so it uses almost no power. If it's broken internally a new 'used' one can be had for around $40 at most junkyards. They spin REALLY easily so it isn't a problem to check them for noise and function.
Old Aug 23, 2012 | 08:42 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
I would argue that the easier "fix" is to simply remove it. Yes, you'll need a new belt, but you probably were due for a new one any way.
Old Aug 23, 2012 | 09:24 AM
RIKIL's Avatar
RIKIL
remove it, I did and no issues
DDDDDMorgan
Sep 13, 2016 08:00 AM
slayerman54
Jul 16, 2011 11:47 AM
synchro
39
Dec 31, 2010 03:30 PM
dbf288
25
Mar 11, 2008 06:49 PM
TexasGuy001
Oct 2, 2001 11:45 AM
