Jacking point - from under the rear diff?
Old Aug 23, 2012 | 03:53 PM
04XLTRUNNER's Avatar
04XLTRUNNER
[quote=flixden;12196671]Yeah, good point. And in that case, it could also actually get a hit in addition.
Has anybody ever heard of a (confirmed) case where jacking from under the diff bent the axle?[/q
Ive never heard of any issues. I think its more of a safety issue than anything because of the stability of the truck by jacking at a single spot in the center. I can tip side to side very easily. Thats what jack stand are for.
Old Aug 23, 2012 | 07:53 PM
Jus2shy's Avatar
Jus2shy
From what I understand, it isn't anything about bending tubes. The issue is that you can "warp" the casing just enough to cause a seal issue between the diff cover and housing and end up with a slow oil leak in the rear end. Most people don't check the oil in their diffs and this would cause it to eventually empty out and you know what happens when metal and metal contact each other. Jacking up the truck by the tubes won't hurt anything, what do you think your leaf springs are sitting on?. The axles are usually designed to be bolted either on top or below the leaf springs as well, in case ford would have have need to do that in a future product. I jack up the differential by the tube and place a jackstand on the tube as well. I usually fit the jack pad right between the 4 bolts that hold the leafspring pack to the axle.
Rob89
Jul 17, 2017 08:43 PM
alchemist1
Oct 3, 2012 10:18 AM
mikeyc0120
30
Oct 10, 2010 06:28 PM
mikecox1
Nov 6, 2009 07:06 AM
captain p4
Offroad & 4x4
Jan 24, 2007 10:03 PM
