Bent rear axle?
Old Oct 4, 2010 | 05:30 PM
mikeyc0120's Avatar
mikeyc0120
Bent rear axle?
Ok heres the problem... I've been told a few times that my truck's rear is somewhat sideways when going down the road straight. I haven't personally seen it cuz I've never been behind my truck to while driving. The rear wheels are at noticeable different distances in the wheel wells. Below are pics of each side looking down from the bed. You can see the pass side wheel is straight with the body line, but the drivers side is kicked out some. The axle is locked into the springs and springs into the hangers/shackles. Nothing seems bent. If the axle was straight but cocked a little, I would think both tires would be slightly out of whack. But since one side is straight and the other isn't I'm thinking the driver's side is not where it's supposed to be and that side of the axle is bent. The last pic is the driver's side axle housing where it goes into the pumpkin. It looks like there's more space toward the rear of the housing than the front. I did measure the rear shackle to the axle block plate and there's at least a 1/2inch difference in the two. So, thoughts, opinions, help? Thanks!
Old Oct 4, 2010 | 06:28 PM
hammer65's Avatar
hammer65
Has it been in a wreck at some point in time? Could be the frame. A good frame shop could tell you. I had a Ranger that way once.
Old Oct 4, 2010 | 06:46 PM
Shake-N-Bake's Avatar
Shake-N-Bake
It does look like one side is goofy based on the photos. If it were me, I would jack up the rear and remove the wheels. I would then get two long lengths of straight metal (tube, angle, uni-strut etc) and clamp them onto the rotors and see if they are parallel to each other. If the metal lengths are long enough, you will be able to see pretty quickly if anything is wrong.
Old Oct 4, 2010 | 06:48 PM
big poppa's Avatar
big poppa
Maybe do a Carfax on your truck and see if their was any reportable accidents. From the looks of it, if thats the case, a side impact going towards the rear tire or somebody caught a high curb or something off road got it. Just some senarios for yaa. To check for a bent axle have somebody roll the truck and look at the tire as its rolling, you'll know if its a bent axle, I had one before on a car.
Old Oct 4, 2010 | 07:09 PM
spdmpo's Avatar
spdmpo
I wonder if maybe the spindle is bent, not the axle tube. You getting funny wear on the tires?
Old Oct 4, 2010 | 08:01 PM
mikeyc0120's Avatar
mikeyc0120
I have never wrecked it or hit anything. However a friend of mine did some body work for me and while he was sanding it for repainting found a bunch of bondo on the drivers door. I can't find any evidence of a bent frame but I'm no professional. However I might try the metal bar/pipe method and think I may get a carfax for it as well.
Old Oct 4, 2010 | 09:07 PM
camodown's Avatar
camodown
On the rear part of the tires, measure from outside to outside, then at the front of the rear tires do the same. They should be the same. Another trick is to take baby powder or chalk dust and dust the rear wheels, drive on rotation and look at the pattern. My drivers rear axle tube was bent really bad and still is slightly bent but was straightened ok.
Old Oct 4, 2010 | 09:14 PM
mikeyc0120's Avatar
mikeyc0120
Yea that seems to be whats happening here. How did you straighten it? Or did you have a shop do it?
Old Oct 4, 2010 | 09:32 PM
rbaker6336's Avatar
rbaker6336
I had a housing from my tri-axle dump truck straightened at a spring and axle shop in Ft Meyers,there should be one in Tampa.Use to be a place on 60 but that has been years back
I would pull the axle and see how much spline wear there is.Being that far out of alignment the axle and side gears may have a good bit of wear
Old Oct 4, 2010 | 10:00 PM
mikeyc0120's Avatar
mikeyc0120
Ok just as long as I wasn't the only one! lol
Old Oct 4, 2010 | 11:30 PM
Franko72's Avatar
Franko72
Molon Labe
Mike, I have a spare rear end sitting at my shop in Sarasota that I pulled from my 99 srw. Its a 3.73. 10.5 sterling axle. If you need it your more than welcome to it.
Old Oct 5, 2010 | 08:54 AM
mikeyc0120's Avatar
mikeyc0120
Frank I would love you forever! lol I would feel a little bad just "taking" something of that caliber tho...
Old Oct 5, 2010 | 09:21 AM
Franko72's Avatar
Franko72
Molon Labe
Ok, I'll take a case of Yuengling light...
My boss is sick of looking at it, I'm tired of tripping over it, I have no use for it. I would feel much better giving it to a fellow FTE brother than getting $30 for scrap.
It has 230k on it, it was just fine when I pulled it, no leaks, noises ect.
It's yours if you want it.
Old Oct 5, 2010 | 09:23 AM
mikeyc0120's Avatar
mikeyc0120
Yuengling light it is! lol That would be awesome. I'll PM you with my info. Do you know to change gears in a rear? I wanted to go 4:10.
Old Oct 5, 2010 | 09:27 AM
Franko72's Avatar
Franko72
Molon Labe
Here it is, I'll be keeping the wheels and the Roadmasters are going on the bosses truck. But its complete including a new VSS
