Lifts (Icon vs Carli)
I'm strongly considering doing a 4.5in lift on my F350 and wanted to get some feedback from the community comparing these two for ride quality, etc. Let me preface this with the fact that I likely will not be doing a lot of serious offroading, but do want a quality lift that will give me an improved on road ride over the stock set up. I will likely go with 295/65/20 Nitto Trail or Terra Grappler tires.
I'm considering the Icon 4.5 Stage 3 and the Carli Performance 2.0 systems. One thing I noted with both is that neither comes with a dropped pitman arm or a track bar drop bracket. Since these are both high end set-ups, I would assume that they aren't necessary?? I'm sure there are some technical diffs in the springs and shocks, but the main difference that I see between the two is that Icon uses a rear block and carli uses a spring pak which eliminates the overload spring for the F350.
I appreciate everyone's feedback.
Thanks, I appreciate the feedback, although I hardly think spending $3200 on the carli performance system with the bilstein 7100s is "skimping out." Is the only difference between the all the systems (save the coilovers) just the shocks that come with the kit?
It's skimping out, there is that much of a difference between the shocks. Differences are full leaf packs etc. Call George at 8Lug Truck gear for comparisons. He was running 2.0's and swapped to Kings. They are called King for a reason. Good luck.
on
I don't know anything about the ICON system other than what Andy has told me. He is very happy with his set up.
Personally, I think that the Carli add a leaf packs are better than just a larger block in the rear. A larger block boes not change the suspension at all. The leaf pack makes the spring more progressive. The rear suspension on my truck is great loaded or not.
I would highly recommend the pintop king 2.5 system the ride is great.
The 7100's are great shocks too but it is amazing how had you can pound on the kings and they just soak it up. If you are going to beat on it at all it is worth the extra IMHO, but I tend to be a bit hard on things
Carli and ICON put some design time into these systems from what I can tell (I know first hand carli did, their system works great). No drop pitman arm but an adjustable track bar is all you get but it works great.
Thanks
Thanks
Spoke w/Nick at 8 lug (george was out), he gave me some good info on the set-ups (performance vs pintop). He says they sell about twice as many pintops as performance (kings vs bil 7100s).
Also gave me some info on the upgrades to the kings (cold temp upgrade, SS shafts). I think I'll go with the later, don't need the heavy shock oil upgrade.
I'm still on the fence on whether or not I'm going to pull the trigger on the lift, but if I do I'm pretty sure I'm going with the Carli setup.
Thanks
Thanks
on
Thanks Andrew, not sure how I left that one out....
Yes get boots on the shock no matter what they tell you. My shafts only lated a year without boots. They got pitted by rocks and then the shocks started leaking. Then you get to buy new stainless shafts at $180.00 each and seal kits and oil and labour and get them fixed!!!!!! NADP and Carli covered everything but the cost of the shafts for me, if not it would have been a $1,000.00 bill.
That's the spirit! Go all out, that is the way to do it if you plan on keeping the truck or you could just dump a ton of money on high end modifications and sell it in 12 months for a huge loss!
Matt, will you be interested in a lightly used carli pintop system in say 16-18mos....if so I'll look you up.....
on
But NADP is putting boots on all open shaft shock from here on in. If you take them off you are on your own.
Regardless, if you can't get them from Carli, you can get them anywhere. Pretty easy to put on before the shocks go on the truck
Thanks
