Clearing engine bay 96 5.0
Old Aug 21, 2012 | 07:14 PM
FordYoungGun35's Avatar
FordYoungGun35
Is there anything outside of the smog pump and charcoal filter on a 96' 5.0 that you don't need? I'm trying delete anything that's not needed.. As of now the smog pump is gone
Old Aug 21, 2012 | 09:34 PM
minnesotafisherman's Avatar
minnesotafisherman
Yeah, your catalytic converters, LOL.
Old Aug 21, 2012 | 09:56 PM
FordYoungGun35
Well I know that there gutted lol
Old Aug 21, 2012 | 09:59 PM
minnesotafisherman
Yeah I was gonna say since you're removing all the other emissions stuff... lol
Old Aug 21, 2012 | 10:03 PM
pfogle's Avatar
pfogle
Be prepared to fight a losing battle if you remove all the 'smog' stuff. In '96 all vehicles went to OBD-II and it monitors a LOT more than the older OBD-I (EEC-IV) did. You're going to be setting all sorts of emissions codes which will make the truck run full rich all the time. So say goodbye to your fuel mileage.
Old Aug 21, 2012 | 10:06 PM
FordYoungGun35
What if I keep the EGR stuff and just remove the smog pump?
Old Aug 21, 2012 | 10:23 PM
minnesotafisherman
Messing with EGR stuff will set off codes and screw fuel/air mixtures etc. up. Best bet is to just leave that stuff the way it is.
Old Aug 21, 2012 | 10:37 PM
FordYoungGun35
Will I gain or lose anything by removing the smog pump
Old Aug 21, 2012 | 11:38 PM
Encho's Avatar
Encho
The Southernmost Mod
I know I lost MPG when I removed mine. There is no gain in doing this.
Old Aug 22, 2012 | 10:50 AM
BigBlueOx's Avatar
BigBlueOx
If your Cats are gutted then you should already have CEL. Also there are vacuum lines in the "smog" pump system. If you remove the emissions valve then you will get a CEL.
Old Aug 22, 2012 | 02:19 PM
pfogle's Avatar
pfogle
The 'smog' or A.I.R. (thermactor) system is controlled by the computer via two vacuum solenoid. TAB, thermactor air bypass, and TAD, thermactor air diverter. The computer opens and closes the solenoids to allow either allow air to be blown into the cat or exhausted to the atmosphere. Also in '96 they included the ability to detect back flow. I don't know how, but that's the code I get right now with a BAD air pump. I get 16mpg out of a RCSB with the 300, m5od and 2.73 rear gears... I should by all rights be getting at least 18 to 19. When I pull the codes it's all related to the A.I.R. system.
Old Aug 22, 2012 | 02:33 PM
Encho's Avatar
Encho
What he said ^, as you can see, it messes the 300. It hurts the 302 performance too.
Old Aug 22, 2012 | 06:00 PM
FordYoungGun35
Well should I remove the air and EGR stuff to? Cause as of now i've just takin off the pump and the charcoal filter behind the battery and
Got a smaller belt.. The big cat is gutted the 1st smaller one thats right off the y pipe is NOT
Old Aug 22, 2012 | 06:35 PM
Encho's Avatar
Encho
The "charcoal filter" you removed from behind the battery is a vacuum reservoir (it resembles a big powedered milk can, right?)... you will really make that truck run like s***... You're asking questions but you aren't listening to anyone. I would say: It's your truck, do as you please with it.
MattOzzz
13
Apr 5, 2017 01:12 PM
ExitLeft
May 16, 2013 12:15 PM
fordnut74
1978 - 1996 Big Bronco
Feb 25, 2004 08:53 PM
redlead3
May 9, 2002 09:17 PM
