Fuel Tank Replacement
Old Aug 21, 2012 | 06:33 PM
JM96F250's Avatar
JM96F250
Greetings all.
I own a 96 F250 and am in the process of replacing the tanks. The rear is done and now I'm onto the side tank. When I ordered the tank I was asked if I wanted a 16 gal. or a 19 gal. Since this truck is a tow rig, I decided to go with the 19 gallon.
Well the tank doesn't want to fit. For a few reasons. One, the hole for the filler is smack dab in the middle of a crossmember. If I slide the tank back and forth, I hit the second issue. If I move it forward, it hits my t/c. If I move it back, it doesn't clear the axle. I think it'd work if the truck was a 4x2 since the t/c wouldn't be in the way. Could that be a mistake I made? Perhaps the 19 gallon tank only fits 4x2s? Or did I just get the wrong tank? I set them side by side and they seem like it would fit, but the new tank is just too long.
Another issue I have are the straps they gave me are way too short.
This truck was an old highway department truck so its a little different than the typical F250. It has a 351 and 4.10s. There are a few quirks about it that make it difficult to identify what parts I have.
Here's the truck:
So any help would be great.
Thanks.
Old Aug 21, 2012 | 06:56 PM
burnout400m's Avatar
burnout400m
Sounds like you need the 16 gallon tank. The longbox super and crew cabs got the 19 gallon tanks. I know all the shortboxes got 16 gallon. I forget which reg cab LBs got the 16 and the 19 but it sounds like the 4x4's got 16's.
Old Aug 21, 2012 | 08:25 PM
wicat3's Avatar
wicat3
my 150 shortbed has the 16 gallon tank its ext cab but the beds should be the same
Old Aug 21, 2012 | 09:26 PM
JM96F250's Avatar
JM96F250
Yep, so the tank is going to be too long. To clear the t/c, it has to be pushed back to where the top of the diff.
Damnit. I ordered this awhile ago and just got around to it today. I'm hoping the local place I got this from will exchange it.
Thanks for the help.
Old Aug 21, 2012 | 09:27 PM
minnesotafisherman's Avatar
minnesotafisherman
This might help you...
I just recently converted my '92 F150 to 4 wheel drive. My truck to start with was a standard cab long box, 2wd, with a 19 gallon tank. When I was putting the 4x4 transmission/transfer case under it, I didn't think it would work at first because of how close the transfer case was against the front tank. With the tranny all bolted in, I have a few inches of space between the transfer case and front of the front gas tank.
The 19 gallon SHOULD fit just fine under yours, but I'm wondering if your transmission is maybe slightly longer or something? That could affect it, depending on what type of tranny it is.
Old Aug 21, 2012 | 10:27 PM
rla2005's Avatar
rla2005
My 1992 F350 4x4 w/5.8L engine and E4OD had an 8 foot bed and standard cab. It came with a 16 gallon side tank and 19 gallon rear.
Old Aug 22, 2012 | 11:49 AM
JM96F250's Avatar
JM96F250
I just exchanged for a new tank. Its identical to the one that came out. Way easier than making the 19 gallon fit. =P
I appreciate the help. Thanks. =]
Dallas2142
Aug 7, 2018 06:27 AM
tbruz
Oct 23, 2015 01:46 AM
79super460
16
Jul 5, 2012 04:01 PM
wildcat421
Apr 26, 2008 07:35 AM
corobv
Sep 8, 2003 09:01 PM
