effect of headers??
Old May 13, 2003 | 07:38 PM
MikeMc100's Avatar
MikeMc100
effect of headers??
I just bought some Dynomax longtubes. will I need to get a chip if I install these or will my truck adjust automatically....or doesn't it matter? I do realize that mods will have to be made for the o2 sensor, but my concern is the truck's computer. Will it adjust what it needs to to account for the headers?? Thanks for any thoughts
Old May 13, 2003 | 08:08 PM
HippieCustoms's Avatar
HippieCustoms
effect of headers??
is it a mass air truck or speed density? Mass air will be no prob at all, if it is speed density, I am not sure, but I don't think it will be a prob either. I have done more extensive exhaust work than just headers to speed density trucks before, and had no probs. But I have also heard that a check engine light stays on after headers were installed. So I would do it either way. Hopefully some one with more speed density experience than me will chime in. Good luck, let us know how it works....Hippie.
Old May 13, 2003 | 08:09 PM
MustangGT221's Avatar
MustangGT221
effect of headers??
It should not be a problem. The only thing that makes a difference is air going into the engine.
Old May 13, 2003 | 08:48 PM
MikeMc100's Avatar
MikeMc100
effect of headers??
It's mass air but it look like i'm ok either way. Thanks for your comments. So i guess if i move the air intake from it's current spot between the radiator and the hood and move so the hose is mounted right in the grille that will cause prob's huh?? Good to know. Now if i can figure out the o2 sensor prob it looks like im good to go. Thanks again. You guys are great. Mike
Old May 13, 2003 | 10:21 PM
HippieCustoms
effect of headers??
moving air intake will be no prob. I made many changes including cam, heads, modified maf meter, and k&n that let the truck still run with little prob's. If you don't go with a "big" cam and head change, your comp will adjust itself to just about anything else you do. Good luck with it.. Hippie.
rusty2872
48
May 1, 2012 07:44 PM
jtharvey
Mar 23, 2007 02:00 PM
Dwinn
Computer Chips & Tuners
Oct 30, 2005 09:32 PM
Hausladen
Exhaust Systems
May 4, 2004 08:03 PM
bigern6697
Jan 16, 2004 10:39 PM
