Homemade parts/tools thread
Old Aug 20, 2012 | 11:44 PM
LITTLE BLACK TRUCK's Avatar
LITTLE BLACK TRUCK
I dident see any thread on this subject so I wanna see some homemade parts and tools you have made to work on your dentside. Heres the manual choke cable I made for my 1bbl carb. Saved 20 bucks.
Old Aug 20, 2012 | 11:59 PM
HIO Silver's Avatar
HIO Silver
I was wandering the JY and came upon a junked Dodge work van with a pair of ladder racks and "Ding!", a light bulb came on. I picked up the pair for $26, modified it a bit, and added about $10 worth of new hardware. The other light bar was sent to fellow FTE'er SuperDuty93. Cost: $23 each
Custom hitch cover made from scrap VW con rods and pistons. Cost: Free!
Billiard ball shift *****. Cost: $1 each at a swap meet.
Old Aug 21, 2012 | 12:00 AM
MikeS29's Avatar
MikeS29
Nice! Don't have any, myself, but interesting topic.
Old Aug 21, 2012 | 05:41 AM
KingBigJoe's Avatar
KingBigJoe
Subscribed due to the thriftyness of this thread & the ideas that I might get from it.
Old Aug 21, 2012 | 07:10 AM
fordnurse's Avatar
fordnurse
Great Idea on the thread.. I will be taking notes!
Old Aug 21, 2012 | 03:37 PM
LITTLE BLACK TRUCK
The shifter ***** are killer!! The light bar is cool as well!
Old Aug 21, 2012 | 04:34 PM
NorthwestX360's Avatar
NorthwestX360
Years ago when I rebuilt a 460, I made an "engine anti-rotation device," as I called it. It was a simple strip of 1/8" X 1" metal with two holes drilled in it. One end bolted to a hole in the flexplate, the other bolted to a bellhousing hole on the engine block. The holes were drilled in such a way that when it was on the engine, it held the crankshaft right at top dead center on the #1 cylinder. That way I could tighten the harmonic balancer and do other work without losing that setting.
Old Aug 21, 2012 | 06:18 PM
Blue and White's Avatar
Blue and White
A "leaf spring pin puller" for a '47 Dodge PW. The pins are headless and captured so you can't drive out from behind.
The leaf spring puller is a grease zerk with the nipple ground off welded to a short length of 3/8" all thread. Combined with a large deep well socket it pulled the pins right out by the zerk hole.
Old Aug 21, 2012 | 08:09 PM
LITTLE BLACK TRUCK
I made these tail light mounts for my flareside. I dident have any when i bought the truck. Dont mind the crooked holes im gonna fill em up and re drill them.. Im gonna repaint them black tomorrow to match the truck.
Old Aug 21, 2012 | 08:22 PM
460 FORD MAN's Avatar
460 FORD MAN
Like they say "Why buy when you can build!"
Old Aug 21, 2012 | 08:29 PM
LITTLE BLACK TRUCK
Exactly!! I even made the tailgate hinges for my ford.
Old Aug 22, 2012 | 12:04 PM
ChaseTruck754's Avatar
ChaseTruck754
Especially when you can build it better
Most of my trucks are things I've built.
Old Aug 22, 2012 | 02:55 PM
robs_seven's Avatar
robs_seven
I made this vacuum canister for the heater controls. Scrap PVC I had laying around and 2 old barb fitting plus a little 5min epoxy. It's not pretty but it works
I also made a new joint for my old worn out steering shaft. Bought a few joints from tractor supply and modified the old shaft. It tightened things right up.
Old Aug 22, 2012 | 03:26 PM
JB78f150's Avatar
JB78f150
Do you think the the u joint you put on would fit on the steering box. I need to do something to fix mine. Did the splines line up?
Old Aug 22, 2012 | 03:36 PM
robs_seven's Avatar
robs_seven
I keyed the new ones, I couldn't find a generic set that had the correct splines.
