"New" Truck Owner Questions
hey guys. Today my father went and picked up my truck (2001 f250 xl 4x4 7.3) but we found a few problems. Feel free to correct me if I'm wrong. The main one is, after about an hour, the truck would only idle and when I stepped on it it lost fuel and stalled. My suspicion is a fuel pump electrical system or fuel filter. Sometimes while I'm waiting for the wait to start light to go off I can't hear the fuel pump as loud as it was earlier. There is also some sort of box with 2 green lights on it that we think may be a remote shutoff (was a fleet vehicle). The next one is stiff steering. Sometimes when I'm idling the wheel is hard to turn and it gets easier when I get the rpm's up. I think the power steering may be leaking but my father and I are going to go through and check everything. Other than that, there are just some cosmetics. Where could I find a replacement bench seat? Also, the indicator to tell me where i am (prnd) is broken off. Where could I get a replacement one. Other than that, I'm glad to join the diesel community! I'll get pictures up when I have time off from school later in the week!
The truck shutting off could be oil related. You may have a weak LPOP and that is not filling the HPOP reservoir when the oil is up to temp. It could also be the ICP sensor or the IPR doing it. Pull the connector off the ICP Sensor and look for presence of oil. If nothing is found, you may need to check low pressure oil pressure and then clean/replace the IPR.
The fuel pump can be noisy when running. You may be sucking air from the tank and that will cause it to be louder than normal. Look into the Hutch and Harpoon mods for the tank.
Not sure about your box with LED's......a picture may help.
Power steering is not the strongest feature on these trucks. If you are at idle you will often find the majority of trucks struggle. You can upgrade to various pumps including the "super pump", but may find it easier to just bring the idle up and turn while rolling.
Tousley Ford can usually get all the parts. Pulling the indicator and the cable is pretty straight forward. Probably takes 30 minutes to get the dash apart to get access.
Thanks for the clarification!
Update: The box underneath the dash was a base for a GPS tracker (was a fleet vehicle). There were multiple wires running back to a high voltage regulator that controlled strobe lights (we got rid of them). We are trying to recreate what happened with the issue of shutting off but it was 7 in a residential neighborhood so we decided to try it once I have time during the day. The carfax shows it was maintained very well just beat up on in the concrete business. We believe the fuel filter is at fault. It was frustrating the first day but at least is was close enough that I could run and pick up the 79 C10 and tow it back. And with the steering we think it's the ball joints. This weekend we will go through and get everything greased up and cleaned. (very clean for 288k miles though)!
A power steering flush may help your problems with steering. But let's get the motor problems fixed first. You've got a list of things to check. Let us know what you find. Also, how much fuel was in the truck when it stalled? The pickup tube in these trucks can crack causing it to suck air with a half a tank of fuel.
OK. In the carfax, does it mention anything about injectors or injector o-rings being replaced?
What oil is in it?
When hot, shut it off, and sit for a minute, then try to start it. Does it start right up, or do you have to crank it a while?
Also, remove the fuel filter and see what if anything is in there.
What oil is in it?
We also still need to know how much fuel was showing on the guage when it stalled.At 288*** miles the mixing screens in the tank may be clogged causing a restriction,also the duck bill in the tank may be cracked causing it to suck air and "run out of fuel" at say a quarter tank.
