Offroad & 4x4
NEW MEAT
Old May 18, 2003 | 12:17 AM
RRMike's Avatar
RRMike
NEW MEAT
The only thing wrong with real low gearing is that the ring and pinion are weaker as you go with lower gears. 4.88 and 5.xx gearing will not hold up quite as well as 4.10 or 3.73.
Old May 18, 2003 | 12:31 PM
rogue69's Avatar
rogue69
NEW MEAT
Thanks guys my 4.10s should be fine
Old May 18, 2003 | 10:23 PM
proeliator's Avatar
proeliator
NEW MEAT
Thats not exactly true. The ring does get progressivly thinner but the pinion doesn't become any weaker. You have to get pretty crazy with the gearing to start worrying about strength. My 5.13s are plenty thick.
Old May 18, 2003 | 10:52 PM
RRMike's Avatar
RRMike
NEW MEAT
That's incorrect. The pinion does become weaker. It must get smaller and smaller as the number of teeth are reduced. Also those teeth must shrink to match the smaller teeth on the ring gear.
Your 5.13 are probably ok but most folks don't have d70's.
With 9" and 44 you don't have to get crazy with gearing at all to worry about strength, especially with big tires.
Old May 20, 2003 | 11:41 AM
bronczilla's Avatar
bronczilla
NEW MEAT
Originally posted by rogue69
bronczilla
You have 4.88s in your bronco. Do you run a 460 or 400?
What is your top speed on the highway?
I just got 4.10s becaous everyone told me to stay away from 4.56s
Im running a 460 in the Bronc. Top speed is about 60 but not sure( not a daily driver).
There is nothing wrong w/ 4:56s maybe someone told you that due to your combo if you have say a 351 w/ 33" tires then 4:56s would be to low but upgrade to 36" tires then it would work....etc,etc... Depends on your preference, rig and what your running.
Old May 20, 2003 | 02:15 PM
proeliator's Avatar
proeliator
NEW MEAT
Actually, Randy (of Randys Ring & Pinion) told me that the pinion becomes thicker to compensate for the thinner ring gears. Looks like we have different information. You're right though, I typically think in terms of Dana 60s on up and it does become more critical with smaller diffs. I do know from talking to allot of shops opinion varies on this topic. Some would say a 4.56 in a 9" is asking for trouble and others say its fine. The tire size is a whole other bag of worms. Personally, I don't think big tires should be run on 9s or 44s unless you put in aftermarket axles and u-joints....even then I'm not real fond of it unless your rig is real light. But, I say run what you want and if you break it get a bigger axle. The only problem with that perspective is that if I break my current setup the only way left to go is Rockwells
Old May 20, 2003 | 03:42 PM
Ken aka Savage's Avatar
Ken aka Savage
NEW MEAT
Love your Bronco, it has the same, well used look as my Jeep CJ's.
I run a Ford 9" in the rear of my latest CJ, with 4.11:1 Quality gears & an Auburn Full Spool, being in a 3000#
Jeep I didn't need to go as big on the rubber, so it runs Interco TSL LTB's 13.50x33" on 10"x15" Centerline wheels.
Let the loud pedal do the talk'n! Check out my Jeep'n homepage.
Savage CJ Home
Old May 20, 2003 | 04:53 PM
RRMike's Avatar
RRMike
NEW MEAT
Actually the opposite is true. As the pinion becomes smaller with higher gears the carrier has to be shimmed further and further to keep the two in proper contact. That's why with some differentials have a cutoff whereby you have to change carriers to go with really low gears.
This is according to Randy of Randy's Ring and Pinion. He directed me to this page for a detailed explanation that I can give to others.
http://www.randysringandpinion.com/gear/g0100.shtml
Old May 20, 2003 | 11:50 PM
proeliator's Avatar
proeliator
NEW MEAT
Well, looks like we were both wrong and both right. I double checked my facts and I had it backwards. The pinion gets smaller (like you said) but the ring gear gets thicker to compensate. Thus the pinion can be considered weaker but the ring gear is actually stronger. So, like I said, the lower gears are not neccesarily weaker, at least in bigger axles. I knew Randy had said one got stronger to compensate but the old memory had it backwards. Thanks for pointing that out. Good link, diffs aren't the black magic that some people think.
Old May 21, 2003 | 12:04 AM
proeliator's Avatar
proeliator
NEW MEAT
Found this pic to illustrate my point...the right is a 3:54 set and the left is an 7:17...you can see that while the pinion is smaller the ring gear is much thicker.
I still say that you have to get pretty crazy (more than 5:00 gearing) in any 3/4 axle before you have to worry. BUT it is a factor that is good to be informed about.
Old May 21, 2003 | 08:55 AM
RRMike's Avatar
RRMike
NEW MEAT
You're right about not really having to worry about this stuff yourself. Your diff's are pretty stout.
I just wanted folks to know there's a drawback to running real low gears with bronco running gear. Not so much the 9 but the 44 for sure.
Once the teeth are broke off the pinion gear what good does the thick ring gear do? That's the point. It's only as strong as it's weakest link.
I'm sure you've found this out the hard way with u-joints and weak axles and stuff like those stub shafts on the 60 you and your buddies have broken
Old May 21, 2003 | 11:27 AM
proeliator's Avatar
proeliator
NEW MEAT
All good points Mike. Yea, I hate those weak little 35 spline alloy Dana 60 stubshafts I haven't managed to break mine yet but my buddies have. Then again, they have serious anger management issues, lol.
a320jock
1978 - 1996 Big Bronco
Aug 1, 2004 08:33 PM
bronczilla
Offroad & 4x4
17
Sep 12, 2003 11:16 PM
bronczilla
Offroad & 4x4
May 7, 2003 02:57 PM
Drawsoncad420
Apr 7, 2002 10:18 AM
