BAD ECM or DIST MODULE ???????
Old Sep 1, 2012 | 11:33 PM
  #106
n4ynu1010's Avatar
n4ynu1010
Bad ECM or DIST Module ??????
Originally Posted by White 97 xlt
Guy: I'm sure you have heard of these folks... Mouser Electronics - Electronic Components Distributor
They have always been top notch for me....
A man can never have too many sources!!!!!
You had better update your arrival dte to Tuesday,, Monday is Labor Day.....
This is True !
Thankyou for the Link , I will Check it out
I wound up paying only $0.30 for the 2 47mfd 25V 105 Celsius , and $0.33 for the 10mfd 63V (same temp rating) , so this whole order with shipping was less than $6 , thats impressive in my opinion considering I had better quality as well , not to mention I will receive them in 2 business days most likely , I just did a search and found them , they had their game on too , they really knew what they were doing , I used to do allot of communications equipment in the day , but now all R&R modules and boards , so I have been out of circulation regarding suppliers now fo rmore than a few years , and we had locally for years a great store that you could get anything in called AVEC ELECTRONICS , the owner died and the family went into a war over it , they did re-open for a short while but was in the end reportedly sold and split for cash value , this place was to electronics and all associated tools and equipment for service , like Pleasants Hardware is to quality and selection in the hardware world , that crushed many of us and forced us to order , those were the days , when we could service ( actually replace the bad part instead of an entire board or module ) something and virtually anything we needed ( even vacuum tubes !) was 10 minutes away , and if they did not have it , they would get it there in 1-3 days !
Those were the days .
I will check that link out.
Guy
Old Sep 1, 2012 | 11:44 PM
  #107
n4ynu1010's Avatar
n4ynu1010
Originally Posted by danr1
I pulled the computer out of my 94 to check it out, years of plowing snow has left fender rotted away behind tire, has left it with a sizeable gap between inner and outer fender. Do not believe for a second it provides protection from water, a lot of it, from drenching the computer driving in rain/slush/snow etc. Just gonna move it to higher dryer location, likely last year for that truck anyway. Bungee Cord to top of under hood fuse box or similar.
While I had it in my hand I opened it, looked pretty good but yea one questionable cap. Wouldn't say it leaked no not yet but likely not far from it either by looks of things. I found was carbon trace from that caps positive leg leading across the board to the nearest diode leg about 3/8" long, carbon trace was about thin as a hair tad thicker maybe. Thought it was a "hair" unit I brushed finger crossed it it crumbled/disintegrated.
Had no signs of troubles, it run fine and fuel mileage "normal" for it. Thinking the damage I did find was from a little water intrusion. While I did find it was "dry" inside we are just coming out of drought conditions here, had plenty of long hot days to dry out. That and or perhaps my swapping batterys in it while running!
I took it to a local TV repair shop just up the road, he's replacing all three caps for 10 bucks plus price of caps. Figured what ta heck he's got a lot more experience with the board level type of repairs then I do = 10 bucks well spent. Told him order enough to do at least two of em, when hes done with that one I'll bring him the one out of my 95 nip this whole thing in the bud.
I think I would be removing and testing the diode as well , if he is experienced regarding soldering then you can cut the lead of the diode on one side half way between the the board and the body of the diode , bend it up a 32nd of an inch (if that) and then test the diode , then bend back and re-solder the lead , very easy , if it traced to the diode , it could be open or shorted even , which would leave yet another problem
Guy
Old Sep 1, 2012 | 11:47 PM
  #108
n4ynu1010's Avatar
n4ynu1010
Oh MY ! LOL , I forgot all about Labor Day , ROFLOL , I can't get a break
Guy
Old Sep 1, 2012 | 11:51 PM
  #109
n4ynu1010's Avatar
n4ynu1010
Originally Posted by Truckin Bob
Criminey sakes, I knew something was awry when the days passed and we hadn't heard from you.
Hope you get to end this saga soon and enjoy your truck.
Still standing by,
Bob
Yeah Bob , I have been fuming , its like I might have to drive to the company warehouse and get them next lol , I pray they make it this time
Guy
Old Sep 1, 2012 | 11:54 PM
  #110
n4ynu1010's Avatar
n4ynu1010
Originally Posted by Lead Head
Mouser, Digikey, all good outfits. Can't get much better then Panasonic capacitors.
This is very True , can't beat the price either $0.93 for all 3
Guy
Old Sep 5, 2012 | 01:58 PM
  #111
n4ynu1010's Avatar
n4ynu1010
DRUM ROLLLLLLLLLLLLLLLLLLLLLLL !
It worked !
I got the caps late yesterday evening , mail did not get here until after 1830hrs , so I immediately replaced the caps , upon removal , I found they were are swelled and getting ready to rupture , and the one that had ruptured , I also found that one of the leads had , I guess , either corroded loose or maybe a controlled arcing or intermittent arcing burnt it or melted to the connection inside the cap , anyway , when I went to de-solder it was not connected to cap internally anymore .
I went this morning and re-installed it and immediately Scanned for codes , no codes !
I know there should not have been codes due to being disconnected but was ecstatic that it interfaced beautifully , very fast also , much faster than before , so then I took it for a 30 minute drive , and throttle was working great , no stumbling , no waning power issues , no hesitation even with A/C on
So I headed back home , and immediately scanned again , NO CODES !!!!!
Although I did run a KOER Test , and found 4 during that even though none are stored on ECM :
DTC 52 Power Steering Pressure Switch ( Easy Fix )
DTC 44 Thermactor Air System Fault ( No Clue ) Will look it up
DTC 33 EGR Fault /Not Closing Properly ( do not understand , no code on ECM for this and I have replaced the Valve , Sensor and EGR Vacuum Solenoid/Switch )
DTC 77 Operator Error during Dynamic Response Test / Wide Open Throttle not Sensed ( Have no Clue , I guess the scanner is telling on itself since it is the operator lol , but test never open throttle that far so maybe I am missing something or just a compatibility issue , I will have to resort to handbook , I may have had to move steering and open throttle though it did not direct me to do so )
So it would appear that the caps were not only the communication issue but the reason I was getting the map sensor fault as well , time will tell about the map sensor as it is original , but all other symptoms gone
Guy
Old Sep 5, 2012 | 02:24 PM
  #112
Truckin Bob's Avatar
Truckin Bob
It worked !
Guy
Man oh man Guy,
That's wonderful that your "journey" finally has come to an end.
All I can say is a BIG THANK YOU for providing the technical electronics knowledge (O2 sensor ....... ugh) in this thread.
I think we all learned a whole lot from this discussion.
Going way back.......do you see why initially I asked you if I may use your electronics knowledge to help in this thread.
I will say, you effectively "took the ball and ran with it" !!!!
Thank you Guy !!!!
Happy driving and enjoy your "new" truck !!!
Bob
Old Sep 5, 2012 | 07:23 PM
  #113
n4ynu1010's Avatar
n4ynu1010
Man oh man Guy,
Thank you Guy !!!!
Bob
Thankyou Bob , I was about ready to do a dance when the Code Scanner came back so quick with an answer solving the communication issue , and was even more excited when I test drove and all issues were gone , now I just have to eliminate the code issues for the KOER test , from what I have investigated thus far , the error 77 is no issue since the test does not incorporate a full throttle initiation , I have also found same may be true with steering pressure switch since I was not instructed to turn wheel .
The EGR code it seems might be vacuum lines , I have replaced the EVP Sensor and Valve as well as Vacuum Solenoid/switch and there is no engine code either , so this may just be a automated test issue as well , but will check vacuum lines and see if there is a issue there , may be .
The one that worries me is the Thermactor which involves multiple controls in relation to the Air Pump and Check Valves , but then again why not a code if this is such a big issue , may just remove Air pump and associated controls , I have read that if you do that it has little if no effect on operation and will not generate codes either , have read several aticles stating that people have even passed emissions tests with removed .
The whole idea of the Air Pump is less than ignorant in my opinion regarding most vehicles but not sure if controls and or air fuel would be affected , have to do more homework .
I am happy that there are not any codes though and the spitting back , waning power and hesitation is gone , more so also that the computer will interface with scanner again too
Guy
Old Sep 6, 2012 | 01:51 PM
  #114
Truckin Bob
Guy
I was pondering your 33 and 44 codes last night..........
You may have switched the electrical connectors (plugs) for the EVR solenoid and the TAB (I think that's what it is) solenoid and they're working, but in the wrong vacuum circuit.
Just a thought for you !!!
Bob
Old Sep 6, 2012 | 04:53 PM
  #115
n4ynu1010's Avatar
n4ynu1010
Bob
The motor was just rebuilt so this could have happened , TY for the idea , I will check it out
Guy
Old Sep 7, 2012 | 10:57 AM
  #116
Truckin Bob
Bob
Guy,
Nix the switched elecrical connectors idea, they're different. I looked under the hood this morning.
Probably the vacuum system is "backwards".
Bob
Old Sep 7, 2012 | 11:10 AM
  #117
n4ynu1010's Avatar
n4ynu1010
Yes , I checked , connectors are different , lol , I should have known that as well , vacuum lines are pretty much not able to be reversed either the way they are configured it is impossible to hook them up backwards at the solenoids , and impossible to hook the valves up backwards as well since one is at the rear of the motor and the other is at the front left bottom , pretty much no fault configuration , going to pull the solenoids today and check to see if electrically good , double check vacuum lines with some carb spray and then check valve diaphragms and coffee can , going to get a vacuum gauge and hand vacuum pump to check diaphragms .
Guy
I am still considering removing the the air pump system all together as it seems that one of the valves are no longer available , I am checking with dealer to day on this in case I find one bad so I will be prepared .
Old Sep 8, 2012 | 08:36 AM
  #118
1800joedaddy's Avatar
1800joedaddy
WOW!!!!!!!
WOW!!!!!!!!!!!!!!!!!
Incredible thread! Found this while doing a search to find the root cause of a problem truck I'm going to buy today. Owner says "I'm done spending $$$" on a 95' 5.0 truck that downshifts for no reason while driving. After replacing every mech sensor/gadget a FORD tech suggested ECM swap. Now that I've read this I will open the box and visually inspect 1st!.
Thankyou Guy for laying out all your elec knowledge! This should be a sticky!
Can you post some pics of where the caps go for us DIY'rs??
Last edited by 1800joedaddy; Sep 8, 2012 at 10:56 PM. Reason: Got the truck home and symptems are very similar to OP's
Old Sep 9, 2012 | 05:39 PM
  #119
Truckin Bob
Originally Posted by 1800joedaddy
WOW!!!!!!!
Can you post some pics of where the caps go for us DIY'rs ??
If I may........
Click here:A9x ECM's (and same years ECM's) Failures Due to Age
That should get you going in the right direction !!!!
Good luck !!!
Bob
Old Jan 15, 2013 | 10:22 AM
  #120
DPDISXR4Ti's Avatar
DPDISXR4Ti
Bumping this thread too as it goes into great detail on the capacitor problem. Note the first post on this page where Guy points out that the capacitors are not all rated the same - one is rated differently from the other two.
They should all be replaced even though it's typically the one closest to the center of the board that fails first (and perhaps only), but the other two will follow. Better to do them all now and replace with better components - the part cost is negligible.
