Steering wheel audio controls
Old Aug 19, 2012 | 04:00 PM
stro1965's Avatar
stro1965
My 2012 XLT steering wheel audio controls are acting up, wondering it it's happened to anyone else. The other day I couldn't skip a track forward on the steering wheel, but I could go backward. That function has since returned to normal, but yesterday I lost the ability to increase volume. I could decrease it, but not increase it. Working normally again today. I have an appointment to have it looked at tomorrow, but with it working normally right now I can already hear their response "could not duplicate, no problem noted".
Anyone had this happen?
Old Aug 19, 2012 | 06:14 PM
Rick Cargo's Avatar
Rick Cargo
About 8 months ago I could not activate the cruise control at all. Then it would work 1 day and then not work for 3 days. I popped out the switch and blew it out the best that I could and since then it has been fine. Just a thought.
Old Aug 19, 2012 | 06:33 PM
4stroke's Avatar
4stroke
Sounds like something like going to the Dr. after you feel better. I have included a list of funnies to maybe make you feel better.
After every flight, UPS pilots fill out a form, called a "gripe sheet," which tells mechanics about problems with the aircraft. The mechanics correct the problems; document their repairs on the form, and then pilots review the gripe sheets before the next flight.
Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by UPS ' pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers. By the way, UPS is the only major airline that has never, ever, had an accident.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit
S: Something tightened in cockpit
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what friction locks are for.
P: IFF inoperative in OFF mode.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny. (I love this one!)
S: Aircraft warned to: straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
S: Took hammer away from midget.
Old Aug 19, 2012 | 07:35 PM
stro1965's Avatar
stro1965
That was good stuff!
Old Aug 19, 2012 | 10:33 PM
biz4two's Avatar
biz4two
Arrow
I've noticed a similiar issue. The seek function on the steering wheel works sometimes...and not other. It usually right after start-up. If I keep pressing the button (forward and back directions)...then it starts working. At first...I thought it was me...not pressing hard enough...but that is not the case.
Another strange issue (normal or not?????) is that the NAV unit preset buttons are very sensitive! OMG...I have set and reset stations because it sets over a current station. Very weird!
Let us know what the dealer finds...I'm curious now.
biz
Old Aug 20, 2012 | 03:45 PM
stro1965's Avatar
stro1965
As expected, dealer couldn't duplicate the problem. Working fine again for now.
Old Aug 20, 2012 | 07:24 PM
Sgt93's Avatar
Sgt93
It happens. I had to turn off my rig and re-start and it would be fine. I took it in and techs said there wasn't a fix.
Old Aug 21, 2012 | 09:01 AM
darren32's Avatar
darren32
Sometimes when I push the volume up it changes the station. Must be something screwy with the switch and resistors. Keep in mind that the audio controls are all on a single circuit. pushing the switches changes the resistance of the circuit. See pdf attached.
Thanks
File Type: pdf
Old Aug 22, 2012 | 06:56 PM
Wizness's Avatar
Wizness
Have a buddy it's happened too. Dealer couldn't replicate it as well. Def sucks. Maybe take a video of it happening with your phone and show them???
Old Aug 23, 2012 | 07:22 AM
stro1965's Avatar
stro1965
Good idea, I'll try that when it acts up again.
Old Aug 23, 2012 | 11:46 AM
Adobe 11SD's Avatar
Adobe 11SD
Pushing the volume up button causes the radio to skip to the next higher preset station.
Dealer could not reproduce and did not fix it.
Old Aug 23, 2012 | 11:54 AM
darren32's Avatar
darren32
That is exactly what mone does. There is only 90 ohm difference between Vol + and seek + (see pdf in post 8). Sometimes it gets confused if I dont push the vol + hard enough.
Old Aug 26, 2012 | 10:53 PM
biz4two's Avatar
biz4two
Arrow
Yeah...I'm not a big fan of the stereo controls on the steering wheel. Espcially the Vol + and - along with the seek >> and << .
IMHO...to small...and just poorly executed. Could have given them a lip like the menu toggle on the left side.
Hey...still LOVING my 2012 SD...so not a show stopper.
biz
Old Aug 27, 2012 | 01:04 PM
Brandon Bloomquist's Avatar
Brandon Bloomquist
I occasionally have that happen in mine, too. You'll want to skip to the next station and go one back instead.
ISUinCR
Aug 1, 2019 09:34 AM
yamagrant
Dec 27, 2011 05:59 PM
Bluzgtr
Apr 30, 2009 07:54 PM
Fomoko1
Sep 13, 2007 10:17 PM
ellmer
Mar 24, 2005 11:11 PM
