Carb tuneing
Old Aug 19, 2012 | 10:26 AM
GillisB93's Avatar
GillisB93
Carb tuneing
I had a edelbrock 750 cfm carb sitting on a bored and cammed ford 400. When i try to adjust the mixture i can screw both of the mixture screws in all the way and the truck will just sit there and run? I cant get the damn thing tuned and i was wondering if that might be to big of a carb and that's what causing this? Any ideas?
Old Aug 19, 2012 | 10:44 AM
650's Avatar
650
My 400 used to have a 780 Holley on it. It was bored a little and cammed up. That carbeurator was way too much for it and ran like a total piece of crap.
Old Aug 19, 2012 | 11:39 AM
kenny nunez's Avatar
kenny nunez
Edelbrock
B93, Have you ever hooked up a vacuum gauge to your engine? If it is between5- 8 inches it is too low. If your cam has too much overlap that is one of the symptoms. You can try calling Edelbrock's Technical service and let them know which cam,intake manifold,timing,exhaust and whether it is manual or automatic along with the converter if equipped. If the manifold vacuum is too low it is causing the power valve springs to raise up the metering rods and dump more fuel into the manifold. That is why you can close the idle metering screws. Good luck, Kenny
Old Aug 19, 2012 | 12:12 PM
montana_highboy's Avatar
montana_highboy
X2....for a proper tune a vacuum gauge is a must have tool IMO
Classic Inlines - Tuning with a Vacuum Gage
DirtyLarry
May 23, 2018 12:11 AM
Montag
Jan 12, 2018 07:20 AM
Dance-Trax
17
Jan 24, 2010 12:26 PM
DutchmanAZ
Oct 5, 2007 10:05 PM
billb7984
Flathead V8 & Flathead 6
Jun 14, 2006 05:58 PM
