Performance and tuneing
Old Aug 19, 2012 | 07:39 AM
os250's Avatar
os250
Hello again everyone!
I've got some questions about some perfeomance mods for my 2006 6.0
Currently I have mbrp 4" straight exhaust, arp head studs and all the goodies that come with the complete solutions kit. I also have the sct itsx tuner. I have custom tunes from mkm.
2 questions I have are what other performance mods can I do for more power and speed. Simple and extreeme ideas are welcome. Also who has the best custome performance tunes? I have one from mkm but I'm not too pleased with it and would like a different one. Any help is greatly appreciated.
Old Aug 19, 2012 | 09:04 AM
AGE mechanic's Avatar
AGE mechanic
Turbo, Injectors and NO2 should about cover it.
I run Matt's tunes and have run Innovative. I like the SRL+ that I am running now.
Old Aug 19, 2012 | 09:07 AM
william_04_x's Avatar
william_04_x
Street machine, weekend racer, or tow beast?
Old Aug 19, 2012 | 09:12 AM
os250's Avatar
os250
SRL? And who is matt lol.
os250's Avatar
os250
Street machine/weekend racer
Old Aug 19, 2012 | 09:20 AM
tex25025's Avatar
tex25025
Any towing or is it straight "street princess"?
Old Aug 19, 2012 | 09:25 AM
os250's Avatar
os250
I tow occasionally but not often...... Maybe once a month at most.
Old Aug 19, 2012 | 09:52 AM
tex25025's Avatar
tex25025
Depending on the weight that you tow, that is going to limit your aspirations on having a street/racing machine. For street applications, the most that I would go is Stage II injectors with a 64 or 66 mm turbo. If you are towing a good amount of weight, then I would go above Stage I and a 64 mm turbo (setup I use and I tow ~16k).
Now, of course, there are other mods that have to be done to the truck as well to help the truck handle this amount of power. Tranny rebuild, fuel system etc. The none fun stuff that is associated with the more intense mods.
Old Aug 19, 2012 | 09:55 AM
cheezit's Avatar
cheezit
NO2 really?
propane is were its at.
Old Aug 19, 2012 | 09:58 AM
tex25025's Avatar
tex25025
Originally Posted by cheezit
NO2 really?
He is a "giggler", what did you expect?
Old Aug 19, 2012 | 10:15 AM
os250's Avatar
os250
I will never tow over 6-8k.......
Can someone explain the propane injection? What's the cost and any other mods needed along with it?
Old Aug 19, 2012 | 10:29 AM
tex25025's Avatar
tex25025
That's still enough weight that I would be hesitate to run Stage IIs, unless you are running something else to keep EGTs down.
One thing that you have to realize is that your peak HP/TQ are going to be much higher then your stock peaks are if you do moderate to heavy modifications on your truck.
Right now my peak HP/TQ are at 3900/2500 respectively. That could affect how things are done on the street when you are towing what you are towing. Or even just general driving. If I am driving respectable, I won't see 3900 on the tach at all. You are going to have to make compromises unless you devote your truck to one or the other.
Gearing lower will also help, but that limits you in other ways, especially on the higher end.
Old Aug 19, 2012 | 11:04 AM
william_04_x
NO2 really?
N2O is much easier to manage, and if the fuel is available, has the potential for much higher power gains.
6.0s respond really well to nitrous.
Old Aug 19, 2012 | 11:25 AM
AGE mechanic
This is Matt for the smart *** Newbie. He has a file called the SRL+, this makes the 6.0L Ford Super Duty fast. lol...
Gearhead Automotive Performance
You are asking what propane does for a diesel? I am the only person in this thread that has given you sound advice for what you asked for. Don't start you carrier here being an ***, it wont get you far.
Old Aug 19, 2012 | 11:26 AM
AGE mechanic
Expect a little more out of you with 10K plus posts. You haven't learned anything
