Burnt engine? -Leaks?
Old May 13, 2003 | 03:05 PM
toast_the_cat's Avatar
toast_the_cat
Unhappy Burnt engine? -Leaks?
Well, you'll probably think I'm pretty dumb, but I promise I'll be smarter in the future.
To start, I have a bad radiator leak, and I've got to fix that. But to make matters worse, I apparently also have an oil leak. The result? I was on a dump run last week, and while idling, waiting to get on the scale, my poor 'ol '73 turned itself off, being dry of those two elements it needed to run well. I quickly put some oil in it, and it will still crank, so it's not completely siezed, but I think I burned it pretty bad, it was stinky like burned engine.
So, what should I do? Would an overhaul, tune-up, oil change, new gaskets and such do the trick? One guy told me my coil is probably fried. I have some experience fiddling with different engines, and I want to climb into the engine compartment and work on it myself, but I could use a few pointers. Any suggestions (aside from 'yeah, get yourself a bicycle')?
Thanks,
Tim in Portland, OR
Old May 13, 2003 | 03:25 PM
Torque1st's Avatar
Torque1st
Posting Legend
If it will crank, make sure you have oil and coolant and try to get it to run. It may have just overheated and not burned up. These engines aren't like the modern engines with wimpy aluminum heads.
Old May 13, 2003 | 03:29 PM
toast_the_cat
Yeah, it cranks, but it won't grab a hold and turn over. I'm wondering if maybe the heat screwed something else up.
but I really just need to jump in and go to town on that poor old neglected truck.
thanks.
Old May 13, 2003 | 05:28 PM
Torque1st's Avatar
Torque1st
Posting Legend
You mean the starter spins but it won't crank then...
Cranking means the engine turns over, either with the old hand crank or a more modern electric starter motor -hehe
It sounds as if your truck has been neglected far to long. Get to work!
Old May 13, 2003 | 06:26 PM
Mil1ion's Avatar
Mil1ion
Get a breaker bar and socket and try and tutn the engine over by hand using the crankshaft bolt to grab on to.
blackestate
Nov 24, 2014 05:22 PM
TheImperial_
Oregon Chapter
Oct 29, 2009 11:11 AM
DCRB
Aerostar
16
Apr 23, 2008 02:35 AM
Hiflyer746
Nov 11, 2007 06:18 PM
ACESN8S
Aug 27, 2004 05:03 PM
