This is not my truck I the video but my 03 f350 5.4 has the same issue. Front passanger side axle us flopping around. Clanking over bumps is driving me crazy. Is this due to a bad hub or needle bearings? My dust seals are hanging like most of yours. I guess I'm just trying to figure out if I need just a needle bearing, a new entire wheel bearing assembally or am I going to have to dig in and do ujoints, inner and outer shafts and seals???????
im gonna say that the needle bearing is no good...... BUT i installed new ball joints, new dust seals, new oil seal(the big one behind the unit bearing) new u-joints, and new needle bearings and my axle still has a little play in it. no where near as bad as in your videos but just enough to jiggle when i grab it. I left it alone since EVERYTHING is new.........
