What is the difference between the Edge Insight CTS Diesel and the Edge Insight CTS?
What is the difference between the Edge Insight CTS Diesel (Part #: 85200) and the Edge Insight CTS (Part #: 83830) The Edge Insight CTS Diesel goes for about another $200 than the other one. Is it ok to run the one that isn't labeled Diesel? I tried to compare them on their web site, not much info really. Anybody with and info or specs, please let me know so I know which one to get. Thanks!
Unless you want a tuner you only want the #83830 which is a monitor only. The other one you have listed is a tuner and monitor combined. I have the insight (monitor only) on my truck and I added the rearview camera as well since it wasnt a factory option and I am very pleased with both.
Hope this helps.
Leon
Hope this helps.
Leon
Hope this helps.
Leon
Hope this helps.
Leon
I'm not sure about the newer part numbers but Edge quit making tuners for DPF delete about 6 months ago. Said they learned that people were using them for on road applications. So, if you're getting it from edge's web site it will be a monitor only or a DPF on tuner. That may well be the difference. The one for the diesel is a DPF on tuner, but that's just a guess.
Nix04SD
03-09-2009 07:25 PM
