Distributor Seized in Place
Old Aug 24, 2012 | 08:40 PM
mejonz's Avatar
mejonz
Originally Posted by redmondjp
I used a large adjustable wrench on the hex portion of the casting, along with a 2lb. hammer, rapping on the wrench handle back and forth. It took a week of doing this, after repeated applications of the Kroil, and one day it finally came loose.
My truck was in running condition throughout the process, and I really didn't want to break the distributor housing.
That's the way I did mine. Worked out good
Old Aug 24, 2012 | 09:12 PM
geoffunkel's Avatar
geoffunkel
I got it! I had some Kroil in my garage, don't know why I didn't think to use it before. I put a couple heavy applications on., waited a few hours. Then put a crescent wrench on it and rapped on it with a small sledgehammer just like redmondjp described and lo and behold it finally came loose. I set the initial timing to 12 degrees and the truck seems to be a lot happier. I tested it under heavy load and no pings or knocks. It looks like all is good. Thanks everyone for the suggestions!
jadmt
Nov 24, 2008 02:29 PM
bustedflush
Jun 3, 2007 01:00 AM
jr27
Aug 15, 2006 09:52 AM
Pilgrim
Dec 28, 2005 08:25 AM
QuangBroncoII
Bronco II
Feb 20, 2004 05:49 PM
