Metal
Old May 13, 2003 | 12:08 PM
nhfire 77's Avatar
nhfire 77
Question Metal
I just thought of another question:
when i start my X when its cold or hasnt completely warmed up, I get this metal-like sound i guess i would describe it as thin sheet metal being crumpled into a ball. It goes away after 1-2 seconds. I have had no problems execept i had to replace my IAC motor in November due to rough start, no start when cold, it solved the problem right away. Could it be lifters? It does not sound like what the typical 2.9 sounded like when the lifters are going. Could it be????????
Old May 13, 2003 | 07:06 PM
1956MarkII's Avatar
1956MarkII
Metal
Would you also describe the noise as a real tinny rattle? If so, then I'll bet it's loose heat shields (for the catalytic converter). Rangers and Explorers are notorious for this.
Old May 13, 2003 | 07:59 PM
jeffrjohn's Avatar
jeffrjohn
Metal
Same sound same solution. It's pretty simple to fix. It just has 2 clips that come loose. I thought is was my converter and was just about to go at it when i found the heat shield loose.
Old May 13, 2003 | 08:28 PM
nhfire 77's Avatar
nhfire 77
Metal
i would describe it as a tinny rattle but a loose heat shield? Wouldnt the sound occur at idle 90% of the time? This is only at a cold start/very lite warm start for 2 seconds?? what do you guys think??
mds1870
3.8 & 4.2L V6
21
Sep 7, 2020 05:04 PM
Forwell
2004 - 2008 F150
Oct 17, 2014 08:22 PM
mikerans
1983 - 2012 Ranger & B-Series
26
Dec 18, 2012 11:02 AM
zaaac
Jan 31, 2010 02:55 PM
F150-100 guy
1997 - 2003 F150
Feb 17, 2006 12:26 AM
