Pulling 2.6 class
Old Aug 18, 2012 | 02:49 PM
fordpride's Avatar
fordpride
Your egt's are going to get high regardless what turbo you have.
Call majestic turbo and see what they can do to your stock turbo. They can build it to a 66mm for half the cost of a d66 I just don't know if they can do anything for the exhaust side
Old Aug 18, 2012 | 07:25 PM
96ford250's Avatar
96ford250
Pulling 2.6 class turbo questions
Yea that's what I figured I'd have to do now could I use SD up pipes and mount a stock "looking" turbo on it because it those up pipes were stock for the 7.3 in later years?
Old Aug 19, 2012 | 06:21 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
The only stock appearing turbo is the D66.
With good tunes it can handle Stage-3's with the fuel turned back.
If the truck is set up just right you woudl probably be in the middle of the pack.
Simplest thing if you're a Ford guy and want to do good in the work-stock class is go buy a '08 or newer Ford truck. They will pull circles around you all day long no matter how much you crank up your truck.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Aug 19, 2012 | 07:40 AM
96ford250's Avatar
96ford250
No thanks on the newer truck parts are way too expensive on those common rail engines
Old Aug 19, 2012 | 11:58 PM
bad12jr's Avatar
bad12jr
Just buy a whole lot of stock turbos or mount a 38r of a SD with an up pipe change. If you have been to many pulls at all watch the manifolds. They are cherry red. Burying a 2000 degree gauges is nothing to alot of guys.
Old Aug 20, 2012 | 12:59 AM
fordman67's Avatar
fordman67
Shazamm 2000? Wow git it! Makes me nervous...
Old Aug 20, 2012 | 05:06 AM
96ford250's Avatar
96ford250
Yea I've seen them get pretty hot but I figured a d66 wouldn't help matters in the egt department
Old Aug 20, 2012 | 06:07 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Originally Posted by bad12jr
..... or mount a 38r of a SD with an up pipe change....
Nope, ain't gonna work. 38R is quite easy to see the difference, the compressor inlet is huge.
__________________
Old Aug 20, 2012 | 06:11 AM
96ford250's Avatar
96ford250
Is there anyway to run stage 3s full out with a stock appearing turbo?
Old Aug 20, 2012 | 07:24 AM
fordpride's Avatar
fordpride
Not reliably. With a d66 Or the BD 66mm and stage 3's turned up every time you hit the go pedal for WOT run it'll be a gamble
Old Aug 20, 2012 | 10:05 AM
96ford250's Avatar
96ford250
Ok so forget the pulling what would I need turbo wise to run the stage 3s
Old Aug 20, 2012 | 10:14 AM
Leemakesmepee's Avatar
Leemakesmepee
96ford250 im not sure what area of northeast ohio your from, but im in lorain county and just going to the fair and seeing them boys pull brings a tear to my eye that my truck cant do that. They have some serious money in their rigs.
last year some girl drove her dads 6.7 and got first. Thought about asking my boss to take his truck this year.
Old Aug 20, 2012 | 10:28 AM
  #28
fordpride's Avatar
fordpride
S471, H2E modifie or something alone those lines. I'd call jake at Irate Deisel tell what your plans are and see what he says.
Old Aug 20, 2012 | 10:49 AM
  #29
96ford250's Avatar
96ford250
Sounds good it's a little ways off yet but possibly this winter
Old Aug 20, 2012 | 11:27 PM
  #30
bad12jr's Avatar
bad12jr
Forgot about that thanks Jim. If your just gonna pull. A modded 6.0 vgt charger. Get creative with mounting it but would still fit in the rules. Couple guys moving some air with them. You'd need a controller but for simply pulling a BP referenced controller could do the trick. Still a factory ford charger.
