Front Spring Help Please.
Old Aug 17, 2012 | 11:07 AM
Lug Nut's Avatar
Lug Nut
As I may have mentioned here before, I'm replacing the 360ci and 4spd in my 69 F250 Camper Special with a 12v Cummins 5.9. The Cummins is much heaver than the 360 at about 1K lbs. I'm thinking I should probably replace the front springs to handle the extra weight. But with what? Was there a 2wd F350 (1ton) and were the front springs heaver and compatible with the F250 front springs? Does anyone know of a source for a heavy duty replacement for these springs?
Thanks
Old Aug 17, 2012 | 02:25 PM
HIO Silver's Avatar
HIO Silver
I believe your best bet is to contact Eaton Detroit Spring Inc. If they don't have an off-the-shelf application they can whip a set for ya.
It would be helpful if you knew the nose and corner weights before ordering a set.
Ford Leaf & Coil Springs - Eaton Detroit Spring
Old Aug 20, 2012 | 11:14 AM
Lug Nut's Avatar
Lug Nut
I called them and they were very helpful. Thanks for the link.
69 Crewcab
Dec 2, 2018 01:44 PM
DeathRangerofDeath
Mar 5, 2016 04:58 PM
Lug Nut
Mar 11, 2014 04:27 AM
truckfella
May 6, 2013 11:34 AM
4dfan
1983 - 2012 Ranger & B-Series
Jun 16, 2011 09:13 PM
