Vacuum Hoses for 4x4
Old Aug 17, 2012 | 07:35 AM
bebeard's Avatar
bebeard
hi all,
I wanted to know for anyone who has replaced the vacuum lines, was it difficult? Any videos?
Thanks,
Brook
Old Aug 17, 2012 | 12:22 PM
mmenzies's Avatar
mmenzies
havent replaced them but have fiddled with them on a couple of occasions. Dont believe that it would be difficult at all. I suspect however that is unlikely that your poblem would be in the lines themselves. Most likely the pump, valve, or the seal in the hub if you are not getting any vacuum but you can troubleshoot via isolation along the lines. A golf tee works well to plug the line at the hubs
Mark
Old Aug 17, 2012 | 12:54 PM
bebeard's Avatar
bebeard
Vacuum Pump
Mark
Hello... thanks for the post... What Valve are you referring too? I can lock my hubs and everything works find..
When you say that I should plug the lines at the hubs, what will that tell me?
Brook
Old Aug 17, 2012 | 01:16 PM
mmenzies's Avatar
mmenzies
have a look at this thread
https://www.ford-trucks.com/forums/1...wd-and-ac.html
there is a a lot of good information in there
Mark
Old Aug 17, 2012 | 01:18 PM
bebeard's Avatar
bebeard
Vacuum Pump
Perfect, thank you!
going to work on it now
Old Aug 17, 2012 | 05:19 PM
bebeard's Avatar
bebeard
Vacuum pump - pressure guage
hello...
I bought a pressure guage, and tested the line, pulled from the hub and when I put the guage on, and turn the 4x4 control, It sounds like a "valve" opening and closing.
any ideas?
Brook
Old Aug 17, 2012 | 05:37 PM
mmenzies's Avatar
mmenzies
The valve throws a pulse for 51 seconds drawing 8 to 10 inches to engage the hubs
Old Aug 17, 2012 | 05:41 PM
bebeard's Avatar
bebeard
Valve
Great... thanks.
I didn't get any "Pressure" on the valve when I disconnected the Vacuum tube from the hub.
Brook
Old Aug 22, 2012 | 10:52 AM
bebeard's Avatar
bebeard
ok.. bought a Mighty Max pump tester, and tested the hubs, both hubs held pressure.
I guess the only thing left is the PVH Solenoid Right?
Brook
Old Aug 22, 2012 | 10:01 PM
Dlinzy's Avatar
Dlinzy
Sounds like my issue to a Tee.... sorry.
i got my Sol from Tousley ~86.00 if i remember correctly.
D
jimjokjv
Oct 5, 2018 05:02 PM
deputydog03
Nov 13, 2015 05:23 PM
stowbilly96
Jul 10, 2015 07:06 AM
LSO1123
Nov 14, 2011 05:33 PM
dyna
Mar 28, 2008 12:36 PM
