coilover?
Old Aug 17, 2012 | 06:49 PM
pdqford's Avatar
pdqford
Originally Posted by zman025
what is the proper name, are the called coils or coilovers i have a code P0301 misfire
You didn't state which year and engine involved.
Some years/engines use COPs (Coil-On-Plug)
and others use Coil Packs and spark plug wires.
Old Aug 18, 2012 | 06:53 AM
alwaysfords41's Avatar
alwaysfords41
If swapping the coil to another cylinder and the new boot didn't fix it then it is either the plug or the injector on the original cylinder.
Old Aug 19, 2012 | 06:17 AM
zman025's Avatar
zman025
it is a 2000 eddie bauer expedition 5.4
Old Aug 19, 2012 | 06:21 AM
zman025's Avatar
zman025
is it possible that it still could be the coil or cop it self , maybe ill get a wohle new coil pack 45$ bt now the batt light is coming on
Old Aug 22, 2012 | 08:05 PM
zman025's Avatar
zman025
well i got a new coil or cop replaced it , seems to run alot better . The check engine light is still on when is was running pretty rough will it go out by its self or should i reset the code to blank , can i just disconect ther batt ofr 10 min or can i go to auto zone to see if they can clear the code
Old Aug 22, 2012 | 08:07 PM
zman025's Avatar
zman025
it seems it still might have a slight miss still but no where how it was running . does it take a few days to start running normal . i feel i should replace the rest of the 6 cops . 2 have been replaced and about 2 wks ago all new plugs
Old Aug 24, 2012 | 08:43 AM
zman025's Avatar
zman025
ok so i replaced the cop #1 it ran good all day , not rough at like it was , and the check engine light went off . later in the day the check engine light went back on i wonder if the cop went bad cause it was a pretty cheap one off on ebay . I will go to autozone and see what code it threw
Old Aug 26, 2012 | 11:36 AM
zman025's Avatar
zman025
it still throwing p0301 cyn 1 misfire , i guess its the plug or the injector , do cheap cop ever go bad in a day . i bought one on ebay for 10.50
Old Aug 28, 2012 | 12:24 AM
dr cabela's Avatar
dr cabela
do your self a favor and just replace the plug anyway....you already have the COP off...for 4 bucks y are you monkeying around when you could have a bad plug
Get used to cylinder misfires......when you find out what cylinder it is just replace the COP AND the plug....its 4 dollars!!!!
a garage will usually replace both for 30 -40 bucks if you cant do it your self
Old Aug 28, 2012 | 07:12 AM
c_hohensee's Avatar
c_hohensee
Yes they can. I bought one of the bargain sets from a recommended seller on ebay and 1 was dead on arrival.
Old Aug 28, 2012 | 07:21 AM
zman025's Avatar
zman025
all the plugs were changed a few wks ago can a plug go bad within a few wks if driving with a bad cop
Old Aug 28, 2012 | 07:24 AM
zman025's Avatar
zman025
it could be the injectors now , i put some injector cleaner in the gas tank in not running as bad before i recplaced the COP . I just put the cleamer in yesturday ill try to drive it around to see what is does
Old Aug 28, 2012 | 09:57 AM
  #28
dr cabela's Avatar
dr cabela
yep..........for 4 bucks take the plug out of the equation
Old Aug 28, 2012 | 12:28 PM
  #29
BAD RONALD's Avatar
BAD RONALD
Forgive this obvious question: Did you check the plug gap out of the box?
Old Aug 28, 2012 | 03:08 PM
  #30
zman025's Avatar
zman025
i bought a new plug and replaced it , i guess ill drive it around and see if it improves
