5.8 help
Old Aug 16, 2012 | 09:31 PM
5.8f250b's Avatar
5.8f250b
5.8 help
i have a 92 f250 with the 5.8 efi motor and im having some issues i cant figure out. the truck seems to run good for a short distance about 1-2 miles, but once it is at operating temp and i keep driving the oil pressure gauge drops to nothing and motor starts to act up. the things i notice are lack of power, rough idle/slow acceleration, popping through the exhaust, and sputtering. any ideas?? thanks in advance!
Old Aug 17, 2012 | 07:30 AM
Edgethis's Avatar
Edgethis
Check the codes. You don't wanna guess and jsut start throwing parts at it.
Fuel Injection Technical Library » How To Run a Self-Test
Old Aug 17, 2012 | 09:32 AM
F250F250F250's Avatar
F250F250F250
When this happened on my '92 F250 5.8L, it was a hot summer day. Took me a few minutes of driving with no power to try switching fuel tanks (mine has two). Once I switched to the other tank (sry, don't remember front or rear), the engine took off like a bat outta hell! I never fixed the issue with the tanks, and sometimes I can drive on the one that failed just fine.
Old Aug 17, 2012 | 11:41 AM
rla2005's Avatar
rla2005
The factory oil pressure "gauge" is well known to be very inaccurate. The only way to verify the true oil pressure is to put a mechanical gauge on it. That noise could be from no oil making it to the important parts of the engine. Let's hope there is another cause of your noise/power loss....
Old Aug 17, 2012 | 12:23 PM
5.8f250b's Avatar
5.8f250b
thanks! i am planning on installing a mechanical gauge in it. the check engine light is not on, can it throw codes and set of the light?
Old Aug 17, 2012 | 01:02 PM
Edgethis's Avatar
Edgethis
There could be stored codes, they won't always cause the light to come on.
Old Aug 17, 2012 | 01:23 PM
Truckin Bob's Avatar
Truckin Bob
Yep.
What they all said.
Make sure you do both KOEO AND KOER tests !!
Bob
Old Aug 17, 2012 | 04:53 PM
5.8f250b's Avatar
5.8f250b
what do i need and how do i run the KOEO/KOER test?
Old Aug 17, 2012 | 05:11 PM
bashby's Avatar
bashby
I think fordfuelinjection.com is the name of the site that explains how to get codes and whatnot.
Old Aug 17, 2012 | 05:17 PM
Edgethis's Avatar
Edgethis
Ford sued him so its old fuel injection now.
Old Aug 18, 2012 | 09:18 AM
5.8f250b's Avatar
5.8f250b
i got the codes 33, 16, 34, 63
16-idm signal not receied
33-egr valve opening not detected
34-pfe or evp circuit above the closed limit of 0.67 volts
63-tps circuit below minimum 0.6 volts
could this cause my problem im having?
Old Aug 18, 2012 | 09:59 AM
Truckin Bob
Yes, most definately so.
You have some circuits that appear to be failing/failed miserably.
I'd go as far as saying at this point you have a pretty severe wiring harness problem, or your computer has gone awry. Your oil pressure guage (nortorious for being inaccurate) dropping to zero confirms that something (not good) electronic is happening when your truck goes into open loop.
I've posted a link numerous times about ECU's (computers) failing due to age.
However, I'm at home right now and can't find it on this computer to provide you the link.
edit: Found the link
Click here:A9x ECM's (and same years ECM's) Failures Due to Age
Because I see so many different unrelated things happening, In my opinion, I'd suggest pulling the computer from your truck and opening it up as a first step.
Others might disagree, but, dang you got alot of things failing.......
That's just my take.
Good Luck,
Bob
Old Aug 18, 2012 | 11:17 AM
5.8f250b's Avatar
5.8f250b
im going to look into the computer first Thank You!
Old Aug 18, 2012 | 03:32 PM
rla2005's Avatar
rla2005
Ford started to transition to 3 digit codes in 1992. If your truck has an E4OD transmission then more than likely you should have 3 digit codes. If you have a manual trans. then you stand a 50-50 chance of getting 2 or 3 digit codes. Before going down the wrong path you need to verify if you have the correct codes.
Did you count flashes or use a digital code reader?
T-Bob has a good point, these trucks are getting pretty old, it is getting to be SOP to check for codes and inspect the PCM for signs of internal failure these days.
Old Aug 18, 2012 | 09:12 PM
Demolishus's Avatar
Demolishus
Im just jumping in here so i will be notified if of results of the ongoing saga. just investigating my own issues, of course half of you know this
