What do high EGT's means? Whats normal operating EGT's straight flat highway temps? Thanks guys.
Anything at 1400F and above means your close to...if not already melting aluminum parts in your engine; specifically the pistons. You can get away 1200F for a short period of time (a few minutes); but for long periods of time your going to cause the pistons to deform. Assuming your running light and no trailer, you shouldn't see anything over 800F.
1250°F for short bursts. 1200°F shouldn't be a problem. 50°F means a lot. Doesn't look like much, but it translates to alot.
The engine can actually withstand much more than that for short periods of time. You defined a short period as a few minutes, that's pretty long to me. In terms of a few seconds, I know guys who regularly hit 1400-1600 degrees drag racing or sled pulling.
I've hit that too, but we are talking like 3-5 seconds.
Also, I wouldn't use what sled pullers do as a marker to test what the truck can or can't handle. It seems like they are always working on something right after a competition. 9 times out of 10 its fixin something that broke at last nights pull.
