Sponsored by: Real Truck
v-10 cops
Old Aug 16, 2012 | 09:20 PM
the beast 1's Avatar
the beast 1
v-10 cops
I have a 01 f250 with the v-10 is there any way to check the coils without expensive test equipment. truck has 225000 on it has motorcraft coils in it. seems like it has a little stumble at idle. thanks for the help
Old Aug 16, 2012 | 09:59 PM
redford's Avatar
redford
FTE Leadership Emeritus
Scan your truck for pending codes, which will indicate which cylinder is misfiring.
To test the COP, swap two of them and see if the misfire follows the COP or stays at the cylinder.
Old Aug 16, 2012 | 10:00 PM
mikeismadness's Avatar
mikeismadness
Clean the MAF sensor and throttle body too. Causes a poor idle along with a dirty or bad IAC
Old Aug 16, 2012 | 10:03 PM
redford's Avatar
redford
Yes, a stumble at idle (on 2V engines) is usually a dirty or malfunctioning Idle Air Control (IAC) valve. Reps sent to mikeismadness.
Old Aug 16, 2012 | 10:58 PM
dkf's Avatar
dkf
How many miles on the plugs? I doubt you will get a code or CEL from a slight misfire on the year truck you have.
Old Aug 16, 2012 | 11:38 PM
biz4two's Avatar
biz4two
Arrow
Hope this video helps...
<iframe width="560" height="315" src="http://www.youtube.com/embed/y7YMMlR8wc4" frameborder="0" allowfullscreen></iframe>
Or another...Troubleshooting section starts at 5.46 ... Also good info at 9.10 regarding using a multimeter to test the coil.
<iframe width="560" height="315" src="http://www.youtube.com/embed/jbJkoX_I_WM" frameborder="0" allowfullscreen></iframe>
Last...
<iframe width="560" height="315" src="http://www.youtube.com/embed/Q6_V6XOJ8Pg" frameborder="0" allowfullscreen></iframe>
biz
Old Aug 18, 2012 | 10:44 AM
the beast 1
v-10 cops
Thanks for yhe replies no codes on the truck plugs have at yhe most 5000 miles took truck on 500 mile trip yesterday will post mpgs later today. Havnt had time to look at videos will do yhat and see if anything will work.
my72ford
Feb 25, 2019 09:27 PM
speedybill
Modular V10 (6.8l)
Jan 18, 2019 07:09 PM
Pwrstrkd"X"
Jan 7, 2013 08:50 PM
rshep
May 8, 2005 11:29 AM
acadia81
Modular V10 (6.8l)
Dec 9, 2004 12:30 PM
