E4OD Speedometer?
Old Aug 15, 2012 | 12:48 PM
danlee's Avatar
danlee
E4OD Speedometer?
I purchased a '94 2WD E4OD trans for the 'M' block motor in my '53 F100. The trans didn't have a tail housing, so I purchased a tail housing on Ebay with a speedometer hole.
When I try to install the tail housing, it hits the large reluctance wheel on the output shaft.
The transmission case casting # is RF-F0TP-70C6-AB.
The tail Housing is RF-E9TP-70C6-CB.
Do I need a different Tail Housing?
Or do I need a different Speedometer Gear?
Or do I need a different Output Shaft?
I can use either a VSS or driven gear for the speedometer in my truck.
Old Aug 17, 2012 | 06:20 AM
danlee's Avatar
danlee
What Transmission is this?
I thought that it was an E4OD, but it may be an 4R100. That Reluctor Wheel will not fit my E4OD Tail Housing. This trans fits a 460 motor.
Bueller
Nov 29, 2017 04:55 PM
mtrosclair
32
Mar 29, 2017 12:00 AM
big ole ford
Apr 4, 2015 10:17 PM
Myatock
Jan 23, 2013 06:53 AM
jeff gammon
Aug 31, 2009 12:46 AM
