Does anyone know how to make this work?
Old Aug 30, 2009 | 07:39 AM
jeff gammon's Avatar
jeff gammon
My 1978 speedo with a E4OD tranny.
Thanks,
Jeff
Old Aug 30, 2009 | 11:35 AM
myoldfords's Avatar
myoldfords
what year e4od? i know that 91 and older e4od had a speedo drive that fits the same speedo head as a c6. you could have the newer ones converted back by changing the tail housing and output shaft.
Old Aug 30, 2009 | 12:19 PM
jeff gammon
Mine is a 94. Thanks for the input
Old Aug 31, 2009 | 12:46 AM
myoldfords's Avatar
myoldfords
btw, the ouput shaft comes out of the front of the trans (bellhousing) so if it is something you want to attempt then you might look into what a trans shop would charge. also if it matters, the older ones used a rod linkage to shift and yours uses a cable, might look into that before you take your trans in.
