1978 - 1996 Big Bronco
bad mpg
Old May 13, 2003 | 12:49 AM
blue88EB's Avatar
blue88EB
bad mpg
i have an 88EB and i get 8.5 mpg. it has efi and a k&N and 3 inch exhause with no muffler and i still get really bad mileage. i was thinking it was injectors. i really don't know what it is i have tried just about everything. could my cats be plugged up? i only have 33s on it and 3.08 gears. any help would be great thanks
Old May 13, 2003 | 01:03 AM
steve83's Avatar
steve83
bad mpg
https://www.ford-trucks.com/forums/s...hreadid=112295
http://www.performanceunlimited.com/projectmpg/
Old May 13, 2003 | 01:00 PM
Lookinfurfun's Avatar
Lookinfurfun
bad mpg
Yeah, it's probably a good idea to give it a good tune-up and do some of the suggestions there in the link that Steve left you for project mpg.
I think the bigger problem could be the 33's w/ 3.08 gearing. Your motor is probably working too hard while trying to get those tires to turn.
Old May 13, 2003 | 01:02 PM
Flash's Avatar
Flash
bad mpg
With 3.08 gears and 33" tires, I'm surprized it will move without holding it on the floor. You need gears-BAD. My Bronco has 3.55 gears and 31" tires and it's sluggish. If you want to run the bigger tires, I would suggest something along the 3.73 gearsset. It will let the motor run at a higher RPM with out having to struggle to pull the truck.
Steve,
Nice links, thanks!
Old May 13, 2003 | 03:15 PM
Jason915's Avatar
Jason915
bad mpg
Go with 4.10's 3.08's are way too high for 33" tires, 3.08's are even too high for 225's. With your overdrive the 4.10's will have a good cruse speed also
Old May 13, 2003 | 07:11 PM
greystreak92's Avatar
greystreak92
bad mpg
WOW, and I though 33's and 3.55's sucked. So, you must turn about 1100 rpm in overdrive at 70 mph... (if you have the overdrive). I only turn about 1800-1900 at 65-70....and that sucks! No "giddyup" to pass and a LOT of downshifting to keep up to speed on the hills. Definately, get 4.10's or 4.11's in it...you will see a major improvement. The problem is the engine being so far out of its power band which for most small block V8's is closer to 2500-2800 rpm.
Old May 13, 2003 | 07:14 PM
steve83's Avatar
steve83
bad mpg
I'm running 32s and I can't WAIT to get back onto 3.08s! I got a LLT brake cable yesterday for my replacement axle, so all I need now is time to swap out the 3.55 axle. If I had OD, I'd probably stick with the 3.55s, though.
Old May 13, 2003 | 09:21 PM
blue88EB's Avatar
blue88EB
bad mpg
I have a 351 and a c6 with a tight torque converter and a shift kit and don't have any problem turning the tires, I will get new gears though because i can peg it in second and I want lower gears to get more power.
