Has anyone used the Pro Comp 2.5 leveling kit on a 2012 F-250 4X4 CC?? Mine sits pretty level but I was wanting to run 35's on Fuel 20x9 Hostage wheels. I figure I will have to lift the rear as well. Also any recamendations on off set on the wheels?
Thanx......
Not to far, like I said I would like to run a 35" tire with plenty of room. I don't like the stuffed look. I haven't planed on fender flares. There seems to be a couple of different offsets. The wheel shop recommended O offset??
Thanx..
Thanx......
I would get some 4 inch blocks for the rear too. If you want to keep the leveled look.
