Higher EGTs whats wrong
Old Aug 13, 2012 | 08:01 PM
Insley95's Avatar
Insley95
I noticed towing my racecar my truck seemed alittle down on power and the egts were about 150 to 200 degrees higher than normal. Truck still makes the 22psi on my dptuner 60hp tow tune, but the boost comes up slow and just gets to 22psi right before it shifts. Last fall in did the HPx, FRx, IC boots, plenum inserts, 50 cent mod, and torqued the rockers and injector hold downs. Other mods are downpipe and exhaust, and intake.
I don't see or hear any leaks, maybe up pipes are leaking??? What do you guys think?
Old Aug 13, 2012 | 08:14 PM
woodnthings's Avatar
woodnthings
More than likely up-pipes leaking. Look at them for soot!
Old Aug 13, 2012 | 09:08 PM
Insley95's Avatar
Insley95
Where are they more prone to leak, at the manifold or at the turbo?
Old Aug 13, 2012 | 09:15 PM
JOHN2001's Avatar
JOHN2001
The gaskets on the collector at the back of the turbo/engine
JT250's Avatar
JT250
Turbo because of the donuts. The fix is to get new uppies from riffraff.
Old Aug 13, 2012 | 09:27 PM
JOHN2001's Avatar
JOHN2001
Unless the funds are not there you could just relocate the gaskets and be good to go again for a lot cheaper but know you will be doing them again. I just changed mine because the uppipes were too far out of reach for my wallet at the time. Once you do the gaskets you'll know better than to want to do it a second time. Not a hard job at all but time consuming for sure. I swapped turbos when I did mine
Old Aug 13, 2012 | 09:39 PM
CSIPSD's Avatar
CSIPSD
Yup... So long as the up pipes are not too galled out you can just throw new doughnuts at it and be good to go.
Old Aug 13, 2012 | 09:51 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
Possible boost leak on one or more of your boots also. What's the outside temps been? Has been 100+ here for over a month now.
Old Aug 13, 2012 | 09:54 PM
CSIPSD's Avatar
CSIPSD
Very good point! Hot air means hotter EGT's and lower boost numbers!
Old Aug 13, 2012 | 10:08 PM
Insley95's Avatar
Insley95
It was nice out when I towed last, only about 80 degrees outside temp. Thinking I might just do new donut gaskets, the have lasted 139k and do the EBV delete and a wheel while I got the turbo out.
Can I leave the pipes attached to the manifolds and change the gaskets?
Old Aug 13, 2012 | 10:29 PM
CSIPSD's Avatar
CSIPSD
Yes... but its a bit more involved then that... LOL
Old Aug 13, 2012 | 11:19 PM
SuperDoodie's Avatar
SuperDoodie
New up pipes donuts should fix you up
Old Aug 14, 2012 | 07:42 AM
Insley95's Avatar
Insley95
I did a pressure check when I got home from work this morning, pumped up to 15 psi and no leaks. Looked at the up pipes at the turbo and can't see any soot on what I can see of the pipes and nothing on the firewall. But I mostly run the 60hp tow tune and it doesn't smoke, if that makes a difference.
I also noticed that the ends of the wheel on the charger look funny, like some of the corners are broke off, no end play or side to side movement and it spins ok, like 3 or 4 revolution if you spin it with your fingers.
Wonder if the the EBV is not shutting all the way, could be my problem. I do have the pesky oil leak that runs down by the starter, not bad, maybe a quarter size drip over a weeks time.
Old Aug 14, 2012 | 11:12 AM
Smokiesman's Avatar
Smokiesman
I don't know what tuner you have but when I got my DP I was going to use 60T on my fiver. But when I hit my first set of small hills my EGT started to climb pretty good. Fig I would be in trouble when I got to my big climb so I put it in 40T and made the climb with plenty of power and EGT's were spot on!! I use the 60T on the flats with no problem.
Smokie
Old Aug 14, 2012 | 06:44 PM
Insley95's Avatar
Insley95
I've been on a dptuner 60t for the past 2 years.
ldfry001
Jul 27, 2012 10:24 PM
nylyon
Jun 2, 2011 09:13 PM
Crazy_Jim
May 1, 2011 06:13 PM
Unrealo4
Mar 2, 2011 11:39 AM
davidson915
Jan 27, 2008 08:16 PM
