Seafoam & Fuel
Received 1,458 Likes
on
Great Stuff!
I have used it in my 6.0l fuel and engine oil for 7 years. When I change the oil I add two cans. I put a can in the fuel tank every other fuel up. I have used it in my boats, farm equipment, etc. for 20 years. Never had an issue, it cured some stalling problems on gas applications and it is a great fuel stabilizer.
DSMMH
DSMMH
I've never been a fan of Seafoam in fuel or oil on our trucks for a big reason. It's a solvent and while it's good at disolving whatever gunk it comes accross, it is VERY good at eating o-rings.
Case in point:
Fall, early winter 2010, my truck had a bad injector (what I later found to be a bad IDM) and I read that seafoam could potentially cure the problem. It did, but it came at a price...
I ran seafoam for some time till I properly diagnosed the problem and got it fixed. Not long after, my truck slowly but surely developed leaks; leaks in places that our trucks don't usually have leaks. Anything that had an o-ring leaked and had to be replaced. To that end, I cleaned and rebuilt the top end of my motor with Viton o-rings. Since then, I haven't had a problem, but it was a very expensive and time consuming fix.
Case in point:
That stuff makes me nervous. Seems STRONG. I put some in the oil on my old V6 Trooper. Had a loud lifter. Ran it for 50 miles and sure enough it fixed it. Oil was BLACK. I am sure it cleaned some things up in there.
I have thought about trying some in the truck but cant bring myself to do it. Now, hearing the guy above that had problems with the orings, I dont think my truck is going to be seeing any.
Lucas diesel/gas additive is also something you don't run in these trucks. Not long ago, (as in two months ago) a buddy of mine (2007 F350) filled up and added some lucas to his fuel to "clean" the injectors. He ran through most of the tank and not long after, injectors #1 and #5 failed. We replaced a them both, but a few others seemed like they weren't too far behind. After an aggressive treatment of both Hot Shot Secret and Diesel Kleen (gray bottle), and changing the filters, we were able to dilute and purge whatever lucas remained saving the other 6 injectors.
