Yet another V code / B code question
Old Aug 12, 2012 | 08:40 PM
Mattb60's Avatar
Mattb60
Have seen different things on this.
Are these the correct part #s ?
2C3Z-5310-HA. V code
3C3Z-5560-CB. B code
Also, does anybody know part #s for U bolts, 4 inch rear blocks and 30mm swaybar ?
Have looked at other threads and dont have a consensus on correct #s
Old Aug 14, 2012 | 09:22 PM
Mattb60's Avatar
Mattb60
Sadly bumping my own thread here with a related question.
For those of you who did this yourself, did you use info from the forum or does Cary or someone else have a printed step by step guide ?
Want to have a local shop do this, but dont know yet if they are familiar with this.
Old Aug 14, 2012 | 10:56 PM
Stewart_H's Avatar
Stewart_H
Cary was not in business back when I did mine. All info was gleaned from the 'net.
Check out the tech folder here in the Ex forum for tips to help you along.
Stewart
Old Aug 15, 2012 | 12:46 PM
f150crewcab's Avatar
f150crewcab
Correct.
Front U-bolts (stock X): F81Z*5705*ZA
Rear U-bolts: I ordered stock rear U-bolts for a 2004 F-250SD for my Modified B code spring. These worked great for stock blocks and had about 1.5" to spare.
As you may know, Ford recommends using new u-bolts and nuts when you swap out the springs.
Old Aug 15, 2012 | 02:41 PM
76HBoyNut's Avatar
76HBoyNut
Just did it a week ago and it wasn't too bad of a job. I had use of a lift and two helpers. Local shop shouldn't sweat it.
Thank you FTE members for all the info and part numbers. I'll have to post my list and costs when I get home tonight.
ldunston7621
Apr 24, 2015 11:00 AM
btdigital
Aug 6, 2011 02:12 PM
sg1099
1997 - 2003 F150
Dec 21, 2010 05:17 AM
orionife
Feb 12, 2008 10:27 PM
