Engine won't start
Old Aug 12, 2012 | 12:29 PM
artyarocha's Avatar
artyarocha
Engine won't start
Hello everyone,
My name Arty Arocha.
I have a Ford Expedition 2003 Eddie Bauer (4.6). One of sparks plug decided to leave the cylinder head for a better life and it took the threads with it. Long story short, I have to replace the cylinder head. I just assembled everything yesterday and this is what happened when I tried to start the engine.
1. First try: Engine started spluttering. Check the code and find out I forgot to plug the MAF.
2. Second try (and following tries). Once the MAF sensor is plugged the car make an attempt to start and just die. I have no code (well I have one code I'll explain below).
Our first assumption was to check the MAF and it is OK. It have the 12V and we checked the signal in it and is working.
Then we check the TPS sensor, it has the 5v and the voltage change when you move a accelerator.
The only thing changed was the DPFE. When I was taking apart the engine, I broke the connector to the hose, now the sensor is useless. And that's the only code I have in the computer, the P0402.
Any idea will be appreciate.
Thanks
If you want to hear how it sounds here is without the MAF connected: http://www.iniciado.com/MAF-No.wav and here is when the MAF is connected: http://www.iniciado.com/MAF.wav
Old Aug 12, 2012 | 02:42 PM
chp10_8's Avatar
chp10_8
What type of scanner do you have? is it capable of going into mode 5
Old Aug 12, 2012 | 03:40 PM
artyarocha's Avatar
artyarocha
I don't have a good scanner, a good scanner, but I have the application Torque (the Pro version).
Well in any case, what I'm looking with the scanner?
Old Aug 12, 2012 | 03:42 PM
artyarocha's Avatar
artyarocha
I cleaned the MAF and check the pressure in the fuel line, it has 45 psi, 5 psi less than what the manual says
Old Aug 12, 2012 | 03:46 PM
chp10_8's Avatar
chp10_8
There's a multitude of things you can do with the scanner bypass certain modules and or sensors for test purposes, you can also run a "Auto Scan KOEO" which is what you want to do, as well as "Auto Scan KOER". This checks all the sensory and will let you know more/less immediately what could be failing
Old Aug 12, 2012 | 03:47 PM
chp10_8's Avatar
chp10_8
FP wouldn't be the culprit in this case, MAF wiring could be faulty as well or the unit could be damaged which i'm 50/50 on. Will it run with the IAC disconnected?
Old Aug 12, 2012 | 03:51 PM
chp10_8's Avatar
chp10_8
Did you put new intake gaskets on, and if so how many did you install, and where did you purchase them at.
The reason being in my experience there have been issues with the intake gaskets from FelPro, they have spacers in them that are not needed causing a vacuum leak.
Old Aug 12, 2012 | 04:16 PM
artyarocha's Avatar
artyarocha
I bought the intake gasket at Advanced Auto Parts and installed the three of them, I don't remember the brand but probably is FelPro. Bad experience with them, the timing chain cover gasket doesn't fit my car.
We check the MAF and it look OK, a little bit pricey to buy a new want only to test.
I will try to see how can I have the KOEO and KOER test.
Old Aug 12, 2012 | 04:25 PM
chp10_8's Avatar
chp10_8
I doubt the scanner you have will do it, let's go a little old school. Get a can of carb cleaner and check the mid gasket on the intake while the engine is running that could be your issue if the gaskets are felpro
Old Aug 12, 2012 | 04:36 PM
alloro's Avatar
alloro
Check the PCV line that runs from the PCV valve to the rear of the intake and make sure it is connected back there. Also, make sure the connector is plugged into the IAC valve.
Old Aug 12, 2012 | 04:48 PM
chp10_8's Avatar
chp10_8
If the IAC is connected try starting It with it disconnected
93Pepe
1983 - 2012 Ranger & B-Series
May 10, 2012 06:50 PM
94MustangGT
Aug 24, 2011 08:23 PM
penman39
Apr 28, 2006 01:47 PM
1234567890
Aug 10, 2003 09:41 PM
