Wierd problem dont know how to explain?
Old Aug 11, 2012 | 07:00 PM
Dyllan78's Avatar
Dyllan78
I just got done replacing two batteries and alt. After i went to drive down the road i noticed rubbing when turning tight. My truck is not in 4x4 to be doing this. I noticed on the front right behind the tire there is some type of leak around the ball joint area. Are these things related and why is my truck doing this? I appreciate any help thank you.
Old Aug 11, 2012 | 07:11 PM
BLADE35's Avatar
BLADE35
Is it leaking Brake Fluid???
Could be relaited I guess Hows the Brake Pads??????
Whats rubbing
Old Aug 11, 2012 | 07:37 PM
berick's Avatar
berick
You sure it's not just condensation from the air conditioner dripping onto the ground? Mine drips quite a bit on a hot day and leaves a pretty good puddle. I can't see batteries and an alternator causing a leak unless you bumped or cracked something.
Old Aug 11, 2012 | 08:55 PM
Dyllan78's Avatar
Dyllan78
The batteries and alt are new, its an oily residue, looks like a bad seal or something. I dont know why it happened. Before i changed batteries and alt my truck died on the highway while i was doing 75 mph, maybe just maybe it did something i dont know. Could it be diff fluid.
Old Aug 11, 2012 | 09:15 PM
BLADE35's Avatar
BLADE35
Yes could be diff leak
theres a seal by pumkin
Old Aug 12, 2012 | 06:25 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Leaking on left or right side or in the middle? What color is the puddle? Did you try to smell the fluid?
shultzaberger
1983 - 2012 Ranger & B-Series
16
Apr 3, 2016 07:52 PM
stlpete77
Sep 18, 2010 09:16 AM
Timon5435
Nov 16, 2008 11:13 PM
Robbgt
Mar 25, 2008 03:45 PM
wycowboy
Jan 1, 2008 09:57 AM
