Vin Decoding information
Old Aug 10, 2012 | 10:52 PM
jefe3104's Avatar
jefe3104
Good evening I just joined this evening,
I was given a 1987 F-250 that my father-in-law purchased brand new. The vehicle currently has over 300,000 on it so I'm going to start working on it very soon. I'm trying to decode the vin number, but I'm running into a problem. The model, cab, chasis type of my vin does not match with anything I can find. My vin indicates F34, unfortunately I can"t find that code anywhere. I hope that soemone out there can help. Thank you
Old Aug 11, 2012 | 05:46 AM
UNTAMND's Avatar
UNTAMND
What exactly are you trying to decode. The vin number or the door tag with all the extra stuff.
Why are you interested in this info. Not much of it is nessisary when fixing the truck.
Or were you just curious.
Old Aug 11, 2012 | 07:18 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE
post the vin, and we will be able to decode it for you.
Old Aug 11, 2012 | 10:18 AM
jefe3104's Avatar
jefe3104
Thanks guys, the only reason that I'm trying to decode is for curiosity. When I tried to decode it I was able to decode everything except for the body style. So I'm curious why this body style F34 is not coming up, I was unable to find in in the shop manual either. Thanks again!
This is the vin# 1FTF F34 N4HPB36742
Old Aug 11, 2012 | 10:39 AM
444dieselrod's Avatar
444dieselrod
What Engine is in it? I can't find anything that says what an "N" code engine is, I am also surprised to see it was built in my old home town of the Twin Cities, I thought they only built Rangers there, not full size trucks.
No luck on finding the body code either.
Diesel Rod
Old Aug 11, 2012 | 10:47 AM
jefe3104's Avatar
jefe3104
It has a 302 EFI engine. Thanks
Old Aug 11, 2012 | 11:45 AM
tjc transport
i ain't rite
everything you need in on this page:
VIN Number Decoder offer to you by Ford Trucks Enthusiasts | www.ford-trucks.com
Your VIN number: 1FTFF34N4HPB36742
World Manufacturer Identifier - 1st, 2nd, 3rd Positions:
Manufacturer: Ford Motor Company, USA
Make: Ford
Vehicle Type: Truck (Completed Vehicle)
Brake Type and GVWR Class - 4th Position:
Brake System: • Hydraulic brake system, Class F, GVWR 7,001-8,000 pounds, None
Line Series, Chassis Type, Body Type - 5th, 6th, 7th Positions:
Line Series: F-Series Super Duty - F350
Chassis Type: 4x2
Body Type: Chassis Cab - Regular Cab
Engine Type - 8th Position:
Engine: 5.0(302cid)
Cylinders: V-8
Fuel Type: Gasoline
Horse Power: 185
Model Year - 10th Position:
Model Year: 1987
Assembly Plant - 11th Position:
Assembly Plant: Twin Cities: St. Paul, Minnesota
Production Sequence Number - 12th - 17th:
Sequence Number: B36742
Old Aug 11, 2012 | 12:01 PM
444dieselrod
So it's a 1 ton with a 185HP 302? Dont think I have ever seen that before. must be a special order thing.
Diesel Rod
Old Aug 11, 2012 | 12:12 PM
tjc transport
i ain't rite
pre 87 the 302 was an option in the 350 2 wheel drive.
i think it was a special order for the 88 model year.
norman2012
16
Jan 1, 2017 07:34 AM
MechaNick702
May 16, 2012 03:05 PM
Smokin'
Dec 11, 2009 12:44 PM
jpat414
Jun 18, 2007 06:35 PM
