Odd EGT readings
Old Aug 10, 2012 | 06:56 PM
rolape2's Avatar
rolape2
Odd EGT readings
I have a 6.9 with P'stroke Non gated turbo. Last time I drove truck EGT started changing rapidly with throttle. Dropping so low I question wether it is working but a little throttle and the temp comes up quick but drops right back down when I back off. Boost seems to come up quicker than before. EGT used to run atleast 200 degree at idle and climb steady to about 900 if I stayed in it, came down slow also. I am afraid to drive truck with out knowing what is going on.
Thanks for help
Old Aug 10, 2012 | 07:02 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
could be the sending unit.
Old Aug 10, 2012 | 07:44 PM
tje2015's Avatar
tje2015
What were your previous benchmarks... before it started acting up obviously.
Old Aug 10, 2012 | 09:55 PM
rolape2's Avatar
rolape2
94 IDIT, I have been wondering about sender. I connections look good, sender is about 1 year old. I have another unit I am planning on put in driver side manifold.
TJE, Was getting 200 at idle, 400-500 running peaking at 900. always gradual climb and drop. Now responds more like a vacuum gauge on a gas motor.
Old Aug 10, 2012 | 10:30 PM
RacinNdrummin's Avatar
RacinNdrummin
Yeah, its gotta be the sender, 200* is a little low for idle... My truck idles about 270 after sitting, and about 300 after a drive...
Old Aug 10, 2012 | 10:51 PM
rolape2's Avatar
rolape2
Took truck for a run. EGT seems to be acting normal but runing a little low. Before wood be at 400 when got home, could get down to 300 pretty easy before shut down. Now drops to 200 and seems to stay there. Also If I gose it, it revs up then dies when it comes down.
Old Aug 10, 2012 | 11:25 PM
tje2015's Avatar
tje2015
Dies as in the truck cuts off? If that's the case sound like fuel promble.
Old Aug 11, 2012 | 08:57 AM
'94IDITurbo7.3
mine idles at 150. doesn't take long to get there either. it will go down to 150 while sitting at a stop light.
Old Aug 11, 2012 | 09:03 AM
whiteboyslo's Avatar
whiteboyslo
Mine idles at or just below 300 as well. And while it doesn't take long to get up or cool down, it's still not that fast. I agree that it may be the sending unit (thermocouple).
Mike
Old Aug 11, 2012 | 11:21 AM
rolape2's Avatar
rolape2
Forgot to mention IP has about 10,000 miles, injectors and engine have about 7,000 miles. glow plugs (ZD9) 7,000. EGT probe about 10,000 post turbo. I have an exhaust manifold tapped for EGT but have not been able to swap yet. Have seperate gauge and probe for manifold. Guess manifold swap will be my next step.
Old Aug 11, 2012 | 09:27 PM
turtlemann14's Avatar
turtlemann14
does it sound good at idle? like there is no way it missing is there?
Old Aug 12, 2012 | 03:57 AM
rolape2's Avatar
rolape2
I have not noticed a miss. It does start a little rougher than it used to, but that is because my cold start advance quit (sensor lead broke).
Old Aug 13, 2012 | 09:34 AM
rolape2's Avatar
rolape2
I did not think about it, my dieing problem could be from turning down IP. It was turned up to high when rebuilt. I have not turned idle back up. I am going out right now to swap driver exhaust manifold and install second pyro there. I will check them against each other and be able to tell if it is sender.
Brettboat
13
Nov 17, 2013 03:57 PM
f350project
Dec 2, 2012 08:58 PM
264WSM
Jan 28, 2012 02:06 PM
Jackcd
Apr 26, 2005 11:57 AM
tdford
Jan 3, 2005 10:11 AM
