Millwakee Sawzall leaks oil
A Sawsall should have grease in the wobble mechanism, not oil.
If it has turned to water or whatever and is leaking
6507 is a basic model number that covers MANY years.
You'll need a series or serial number to order parts.
There should be a felt seal and retainer at the front of the case on the shaft.
parts 55 & 56 in the diagram here.
Milwaukee 6507-20 Parts List and Diagram - (SER 182A) : eReplacementParts.com
If it's been run long and hard enough without any maintenance to be puking "oil" it may be too worn out to bother trying to save.
