ICP acting up after recent work.
Old Aug 9, 2012 | 11:52 AM
Rusty Axlerod's Avatar
Rusty Axlerod
So my '06 has almost 800mi since oil and EGR coolers and STC update. On a cold start (less than 80*) my ICP (on ScanGauge) starts at 800+ and creeps up to 1100+ at idle. If I drive the truck it will go a couple hundred yards then suddenly accelerate and engine noise increases. About every third time this happens I get a CEL and code 2284 -ICP range/performance. If I let it sit and idle, when ECT gets up to 120 or so ICP will slowly drop as it continues to warm up until it's down to 580 ( normal for me). Interesting also is that IPR is rock steady at 14.1 through all this. It will grudgingly go up if I try to drive it. Once ICP is acting normally, IPR straightens up also. Truck runs well and no issues after warmed-up. Quick look at ICP sensor and wiring everything seems ok. I'm thinking pull the IPR and check screen, am I on the right track?
Old Aug 9, 2012 | 12:55 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Good stating point I think.
IPR values:
KO=14.84 LI=24 HI=40.60 OR=0-50 %
Old Aug 9, 2012 | 02:39 PM
npccpartsman's Avatar
npccpartsman
Sounds like the IPR screen is clogged to me Rusty. Mine was doing the same thing but I didn't get a code on my 04.
Old Aug 9, 2012 | 03:42 PM
Rusty Axlerod
Thanks guys, I was afraid of that. ICP is so much easier to get to. A couple people warned me that it's common to trash the screen after repairs, hopefully valve is still ok. My co-worker I borrowed the socket from before is on vacation, just ordered one for myself from local parts store.
If the screen has trash on it, can I just clean it? It's new. I also still have my old one, it looked fine when I pulled it. I assume if the screen is broken I'll need a new IPR?
Old Aug 9, 2012 | 04:01 PM
npccpartsman
my screen was covered with lint and it's easily cleanable. I had a new IPR so I put it in. I'd try cleaning it before replacing it with only 800 miles especially if it doesn't have a hole in it. If you still have problems then...........
Old Aug 9, 2012 | 04:14 PM
Rusty Axlerod
Looks like Saturday morning is planned.
My first thought when I saw the 2284 was to snag a ICP sensor and a 5min swap, but thanks to the heads up I knew to look a bit past the simple fix. Glad to be a FTE member!
Old Aug 9, 2012 | 08:41 PM
BLADE35's Avatar
BLADE35
I had a Little Surge today to Rusty was thinking of pullen my IPR this weekend to
Iv got 15K since oil cooler work
Im Due for an Oil Change though so I may due it first before pullen IPR to check screen
NO DTC for me from SGII anyway so might check another code reader I have
Surge was Minimal I wouldnt of known it if I didnt listen for it
are you going to pull Turbo???
Old Aug 10, 2012 | 07:09 AM
Rusty Axlerod
Gonna try and leave turbo on but I won't fool around too long before I yank it if it doesn't go well.
Old Aug 10, 2012 | 07:59 AM
npccpartsman
Turbo removal not required although I did it from top and underneath. The special socket would have made it a LOT faster but I had to manufacture one.
Old Aug 10, 2012 | 09:35 AM
BLADE35's Avatar
BLADE35
I know Dukie got his out with a crows foot style wrench
what size socket was it Rusty or anyone???
Old Aug 10, 2012 | 09:38 AM
Rusty Axlerod
I can post for sure size Saturday but I think it was 34mm.
Old Aug 10, 2012 | 10:35 AM
BLADE35's Avatar
BLADE35
Here is what I found in my Notes Rusty
IPR SOCKET= 1 3/8 CROWS FOOT ANOTHER OPTION IS A 36MM SOCKET
ICP SENSOR= 1 1/16 INCH SOCKET DEEP
Old Aug 11, 2012 | 06:05 PM
Rusty Axlerod
Socket is a OTC 6765 OTC6765 OTC TOOLS 6765 - Ford 6.0 IPR Inject Pressure Regulator Socket
It doesn't say on it what size it is but it's smaller than the nut on the oil filter cap so I think it's a 34mm. 36 would probably work ok as 2mm ain't much difference on a socket this size.
Old Aug 11, 2012 | 06:09 PM
bismic's Avatar
bismic
1 3/8 is 34.925 mm. I think a 34 mm socket would be a touch too small
Old Aug 11, 2012 | 06:12 PM
Rusty Axlerod
Hey Mark,
Is there a general rule of thumb on these trucks about what's metric and what's SAE?
