1978 - 1996 Big Bronco
engine swap?
Old May 12, 2003 | 05:09 PM
kharvey's Avatar
kharvey
engine swap?
What fits or is directly interchangable with a 351M for my '79 Bronco? The 351 sent a rod through the bottom and I want to put in a 300 big 6......What about bellhousing bolt patterns on the C-6 Auto trany?
Old May 13, 2003 | 01:32 AM
greystreak92's Avatar
greystreak92
engine swap?
I think you are the first person I have seen post that they want to drop motor size in their Bronco. But, that notwithstanding, I believe that the 300 I-6 and C-6 tranny combo. was a factory setup at some point in time so it should be a very "doable" swap.
Old May 13, 2003 | 02:06 AM
blue88EB's Avatar
blue88EB
engine swap?
i just put a 400 big block in my 80 bronco that had a 351m. bolts right up to the C6.
Old May 13, 2003 | 04:24 AM
christop43's Avatar
christop43
engine swap?
Go with the 400M, might be hard to find parts for it but it can blow the 300 six out of the water.
Old May 13, 2003 | 10:51 AM
Kemicalburns's Avatar
Kemicalburns
engine swap?
the bolt pattern is different between the 351m and 300-6. so you would need to find a C6 that was already mated to the 300-6. shouldnt be to hard and is a great swap, gets decent gas mileage and is a great wheeler, lots of low end grunt. and with a good four barrel carb and exhaust and it would really improve the performance. I believe they even offer cams that would increase performance as well. check out cliffordperformance they offer all kinds of good 300-6 stuff .
later
Old May 14, 2003 | 10:06 AM
Steve_Uzi's Avatar
Steve_Uzi
engine swap?
Down grade?
Drop a 460 in your '79! it will really wake that thing up! Even if you drop a Stock 460 in there...
Like the previous guy said, you will need a different C-6 tranny to bolt up to the 300, the 300 has the same bolt pattern size as the 289,302's and the 351W. The 351M/C, 370, 400M, 429, 460 all use the Big-Block C-6.
Also make sure if you do drop down to the 300 I-6 that you get the correct torque converter for the 300 I-6. It is more important when you change in a 429/460, See Below:
1971-91, 289, 302, 351, 400, 429, 460 cid with 1.375" crank pilot*
1971-91, with 1.250" crank pilot*
1966-84 332, 360, 390, 406, 427, 428, (1967-71 429) cid with 1.850 crank pilot
-STeve
Old May 14, 2003 | 06:37 PM
kharvey's Avatar
kharvey
Smile engine swap?
Thanks for all the info. I just secured two engines for the Bronco. Both are from Bronco's. One is a 351M and the other is the 400.
P.S. I didn't realize the 351C was a big block!
Old May 15, 2003 | 02:00 AM
1993F150XL's Avatar
1993F150XL
engine swap?
The 351C uses the small block bolt pattern, unlike the 351M/400.
Old May 15, 2003 | 05:17 AM
kharvey's Avatar
kharvey
engine swap?
See previous post....I thought the 351C was a small pattern ! Motor On!
Old May 15, 2003 | 07:12 AM
Steve_Uzi's Avatar
Steve_Uzi
engine swap?
Ah.. Ok... my mistake.... I know that there are 3 types of bellhousings for the C-6
FE 360/390/406/410/428
335 series 289/302/351W/351C <--- I just learned
385 series 351M/370/400/429/460
Old May 15, 2003 | 07:24 AM
SupaFord95's Avatar
SupaFord95
engine swap?
I'm not real familiar with the 429 and 460 . Are these a good engine selection over a built 351W? What vehicles were the 429 and 460 available in? Are these engines available for fuel injected trucks . Are parts interchangable from the 351W ? Thanks
Old May 15, 2003 | 08:23 AM
Steve_Uzi's Avatar
Steve_Uzi
engine swap?
There is no replacement for displacement.
I have a 1986 Bronco Eddie Bauer with the 351W-HO and 3.50 gears. I also have a 1984 Bronco XLT with a mildy Built 460 and 3.50 gears. (pushing approx. 400hp) There is a HUGE difference in acceleration and towing. The 429/460 will give you alot more torque than a 351W.
From what I know, 429's were available in the late 60's / early 70's. I know they came in Mustangs and Thunderbirds. 460's have been in everything from the old mammouth wagons, to lincoln continentals, etc. They were popular options for 3/4T and 1T pickup trucks up until about 1996 or 1997. They came w/carbs and with fuel injection. Mostly mated to C-6 spd and E40D 4 spd autos, they also had 4 and 5 speed manuals behind them.
The biggest thing to consider when deciding between a modified 351W or a modified 460, is that the 460 swap into a bronco is going to cost you some $$ about $1600 (motor mounts, oil filter relocation, C-6 Big block tranny, etc) when all said and done
I did the swap and LOVE IT! I will love it even more when I replace my aging leaf springs in a few weeks and add on Road Masters active towing suspension add-on
http://www.activesuspension.com/index.htm
Old May 15, 2003 | 11:38 AM
mrwizard's Avatar
mrwizard
engine swap?
The only 429 that I ever heard of coming from the factory in a Mustang was the Boss 429, and that's a whole different beast. I had one that was literally crammed into a '69 Mercury Cyclone CJ. Original engine blew up and the guy couldn't find another 428CJ, so he dropped in a 429. He said the stock 4 bbl 429 was just as strong as the 428CJ. I did a few little mods to it after I got it. That Cyclone was a big, heavy car and that 429 could make it fly! Big engines make big torque!
Old May 15, 2003 | 04:35 PM
kharvey's Avatar
kharvey
engine swap?
Ok everyone. Second question.......Since the 351M is a "Big Block" does that mean it shares the same block as the 400? 460? IF yes, then the swap from a 351M to a 460 would be much less than $1600 right? Other than motor mounts and a torques converter......
Old May 15, 2003 | 06:06 PM
Steve_Uzi's Avatar
Steve_Uzi
engine swap?
Ok.. first off, the 351M Does share the block with the 400 but DOES NOT share the same block as the 370/429/460.
Yes, you are correct, if you swap in a 460 from a 351M/400 you WIIL NOT need a different C-6 tranny....
