Engine swap - '92 Mustang 5.0HO/AOD into '66 F100
#137
The truck will have to wait for the "show quality" work until I finish my '37 Ford streetrod.
#139
#142
Thanks, guys!!! I love this car. My dad & I built it when I was in college. I drove it quite a bit and when I first moved to California, it was my daily driver for 3yrs. It was time to change and repair some things. Of course, one thing leads to a thousand more!!!! So, it's slowly getting a complete redo. My only set backs are time & money....Argh!!
#143
Ok, so I'm starting to make a little progress on my truck. Since I last posted, I decided to bite the bullet in move the gas tank under the bed. I've resisted because I didn't like most of the options for the filler door but hopefully my solution will work well for me.
I bought the '66-68 Mustang tank from Tanks Inc that was already modified for fuel injection with an in-tank high pressure pump. The filler neck bolts to the tank so I was able to modify it pretty easily. I bought a 2 1/4, 90 degree elbow exhaust pipe and cut it to fit my filler neck. The goal is to put the filler behind the license plate. Here's the tank with the frame I built and the modified filler neck: sorry if this pic is a little dark.
Here's how it's going to look from the side. When I get the tank painted and run the exhaust out the back, you won't even notice...
Here's the coolest part.....I installed a flip down license plate bracket...
And cut a hole in the bumper for the gas filler. I'm using a tightly sealed push-thru cap so I don't even have to unscrew it to put gas in it!
Sorry these pics turned out so dark. I'll get some better ones. I had to take it apart to finish welding and for painting so more details to come....
#145
I hope it all works as planned!
I just re-read what you wrote, Bill. You're right, the rear-mounted fuel tank didn't always have the best outcome.....
#147
Similar setup as yours
I have a '94 Mustang 302 - 5.0 in my '66 with a Holley 600 and MSD ignition. I've been running a C-4 with a 3.50 rear end, but I just ordered a Monster AOD with a Lokar cable mount shifter. I'm anxious to try the AOD/3.50 combo. It was always hunting for another gear. Regards, Ace
#148
Thanks for chiming in!
Randy
#149
No, Bill, Pintos had a big honkin' gas cap on the side above the rear wheel! A lot of 60's GM cars had the spring loaded license plate, though.
#150
