white smoke?
Old Aug 7, 2012 | 05:52 PM
deano-was-his-name-o's Avatar
white smoke?
My buddy was following me. We were going down a hill. I let off the gas with the over drive off to slow for a stop light. Was pulling an empty car hauler. My buddy said there was 2 puffs of white smoke. Then it wouldn't do it again
Old Aug 7, 2012 | 07:26 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
was this with a fully warmed engine,or did you just head out?
Old Aug 7, 2012 | 07:48 PM
I just left work maybe a Mile down the road. But before that about an hour before, I ran into town. Then I had the truck idling for about 10 min while I closed up shop. Then I headed out, and that's when I hit the down hill
Old Aug 7, 2012 | 07:49 PM
So she should have been up to temp. I just changed the radiator, hoses, thermostat on Monday. Don't know if that had anything to do with it
Old Aug 7, 2012 | 07:55 PM
FORDF250HDXLT
white smoke is either coolant or unburnt fuel.
how many miles on the injectors?
Old Aug 7, 2012 | 08:59 PM
I really dont know. the truck has 230,000. The motor was replaced because of cavitation before I got it. I got it at 185,000. Dont know it tgey replaced them then I would think so, but not sure
Old Aug 7, 2012 | 09:00 PM
Is there another sign I can look for?
Old Aug 7, 2012 | 11:22 PM
FORDF250HDXLT
you can tell by the smell.if it smells sweet like coolant,or rich like fuel.
before i changed injectors,mine blew white smoke for a much longer time than it should at cold start.it made my eyes water when loading up the underbody tool boxes.
changed them and i had a smoother idle,no more engine stall on quick decel,and no more watery eyes in the morning loading tools.
Old Aug 8, 2012 | 12:05 AM
When idling I do smell a lot of diesel. I will pay more attention tomorrow
Old Aug 8, 2012 | 10:37 AM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
sounds like it might just be a case of injectors not feeling to well.
Old Aug 8, 2012 | 02:03 PM
If it is injectors. Can I Test them?
Old Aug 8, 2012 | 02:11 PM
'94IDITurbo7.3
have them pope tested for pop pressure and spray patter. it will tell you if you have any leakers.
Old Aug 8, 2012 | 02:30 PM
Ok cool. Thanks. If it is them, should I replace them all? Where and what kind do I get?
Old Aug 9, 2012 | 09:01 PM
Ok I finally saw it. I fired up the truck. The temp gauge was on cold. There was white puffs coming out . Then it was a solid light cloud. Smelt like a lot of diesel exhaust. When the temp got to the first line the smoke quit. Ran into town down the same hill, foot barely on the gas, the truck felt like it was cutting out. Put the pedal down and it runs fine. Still sound like injectors? I don't know if its just me but feels like the truck doesn't have the power.
Old Aug 9, 2012 | 09:06 PM
FORDF250HDXLT
i wouldn't even mess with the time or $ to have them tested.they sound long overdue for replacement to me.
once you replace 'em,then you'll see how obvious it is to come to this conclusion of worn out injectors.
she'll idle so smooth you'll think you swapped in a newer engine.power and economy will go up.
running rich smell will be gone,along with all but a tiny puff on start up and perhaps a small cloud in the winter for first min or two.
