Hirollin: If you open the hood and look down on the headlight assembly you will see 2 small hexhead bolts pointing up, there is one on each side- one will be next to the grill(easy to see) and the other will be over by the fender and its in back and down behind the assembly, but easy to see and get to!!
The bolts have a torx fitting in the middle of bolt also!
The back bolt controlls the up and down movement and the front bolt controlls the side to side movement !
Hope this helps, Lenny
