HPOP Question
Old Aug 6, 2012 | 11:29 PM
F450 Aaron's Avatar
F450 Aaron
HPOP Question
I have another leak, which is coming from I believe the HPOP non-serviceable plug. I have some extra cash and am thinking of getting the T-500 and swapping it in place since I'll have the pump out. Are there any mods that need to be done before changing the HPOP or can it be done on a mostly stock truck? Would I need different tunes?
Thanks!
Old Aug 6, 2012 | 11:38 PM
BigAlsPSD's Avatar
BigAlsPSD
Nothing is required, You may actually benefit a little noticeably with the pump.
Old Aug 7, 2012 | 05:01 AM
JOHN2001's Avatar
JOHN2001
It's a direct swap like bigal said. To get the full benifit you could have your chip reburnt, I don't know how your tuner works but that's with DP. You don't have to though. If you haven't replaced your hpop lines yet and there still the factory lines I would recommend that you replace them while you have it apart
RA101725
26
Aug 15, 2019 12:12 PM
sbraatz
Oct 25, 2018 11:01 PM
Barndon
44
Jul 27, 2010 12:00 PM
knecoli22
Aug 5, 2009 09:04 PM
caverjoe
Jul 15, 2007 05:44 PM
