P0720 Output shaft speed sensor code?
Old Aug 6, 2012 | 08:09 PM
MikeRizz's Avatar
MikeRizz
I just replaced my starter and on my first ride after replacing it the X started to stumble a bit, and then would stall out at almost every stop light. It threw a CE light and I pulled the code P0720. I searched here and it seems most guys say this is a C.O.P. issue. If it is a bad C.O.P. would it stall like that?
I did have the battery disconnected but I made sure the terminals were clean and tight. Is this a coincidence or did I do something while changing the starter?
Old Aug 6, 2012 | 08:28 PM
TrdLtly's Avatar
TrdLtly
TreadLightly
What was happening with me was the idle would drop and then stall, but I also had the P0722 also. Try some free things first: Clean your IAC and MAF first. If that doesn't do it then I would start looking at COP's.
Old Aug 6, 2012 | 10:50 PM
Cactus Jack's Avatar
Cactus Jack
I had the exact same thing happen, it was a COP. Once I found the bad COP changed it out, disconnected the battery and the code cleared. Runs great now. I'm betting it's a COP.
Old Aug 13, 2012 | 07:58 PM
MikeRizz's Avatar
MikeRizz
I tried the free things, same issue. I am going on a long haul trip this week ( towing ) and did not have time to diagnose which coil it is so I dropped it off at the Ford dealer.
Old Aug 13, 2012 | 08:20 PM
MikeRizz's Avatar
MikeRizz
Does anyone know the Ford TSB that related to a bad C.O.P. flashing the CE light and OD light? I saw it on here when searching last week but cannot find it now!
Old Aug 13, 2012 | 08:27 PM
MikeRizz's Avatar
MikeRizz
Found it!
Technical Service Bulletin 5-22-08
1998-2005 MULTIPLE VEHICLES - WARNING LIGHTS FLASHING - TEMP GAUGE PEGGED HOT OR COLD - TACH OR SPEEDO BOUNCE - DRIVEABILITY CONCERN - UNEXPLAINED DTC'S
SOME 1998-2005 VEHICLES EQUIPPED WITH A GAS ENGINE THAT USES A COIL-ON-PLUG (COP) SYSTEM MAY EXHIBIT ONE OR MORE OF THE FOLLOWING CONDITIONS DUE TO RF INTERFERENCE ON THE SCP/CAN NETWORK: ABS LIGHT FLASHING, A FLASHING FAIL SAFE COOLING LIGHT, TRACTION CONTROL LIGHT FLASHING, INTERMITTENT 'BUMP'(MISS), TEMP GAUGE PEGGING HOT OR COLD, TACH OR SPEEDOMETER BOUNCE, BUCK/JERK AT CRUISE, AND/OR UNEXPLAINED CODES. THERE ALSO MAY BE AN INTERMITTENT LOSS OF RPM. PRIOR TO FOLLOWING NORMAL DIAGNOSTICS FOR THE SYMPTOM, USE TSB 05-22-08 TO DETERMINE IF THERE IS A CONCERN WITH A COP. MONITOR POWER BALANCE TO SEE IF A CYLINDER IS DROPPING OUT DURING CONCERN. IF POWER BALANCE CONFIRMS A CYLINDER DROPPING OUT AT THE TIME OF THE CONCERN, PERFORM THE COP STRESS TEST FOR THE SUSPECT CYLINDER'S COIL TO VERIFY INTERNAL COIL SECONDARY FAILURE.
Old Aug 13, 2012 | 08:44 PM
TrdLtly's Avatar
TrdLtly
TreadLightly
Here is the pdf of the TSB: http://www.stangpit.com/wp-content/i...sb/05-22-8.pdf
Old Aug 21, 2012 | 09:37 PM
MikeRizz's Avatar
MikeRizz
For the archives, it was a bad C.O.P. as I thought. They replaced coil # 7 and a new plug it it runs great again.
Old Aug 22, 2012 | 06:24 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
Thanks for the confirmation. COP's strike again!
bigbugman
Jun 30, 2023 04:45 PM
dsorrell06
Jan 19, 2013 10:46 AM
bigwhitetruck01
Dec 30, 2012 12:02 PM
hamiltonfighter
Jul 2, 2012 10:27 PM
TenPlugs
Modular V10 (6.8l)
Sep 21, 2006 05:53 PM
